| New Reply |
Why is the proton so heavy? |
Share Thread | Thread Tools |
| May4-11, 11:51 AM | #1 |
The quarks that make the proton are up, up and down with masses of around 2, 2 and 4 MeV/c^2 respectively. So, how come when added them together we arrive at a particle with the huge mass of about 931 MeV/c^2.
The only reason I can think of to explain this mass difference is the mass equivalence of the binding energy of the 3 quarks, however, I'm a little hesitant of this explanation because the mass difference is so large. I've looked around on the internet and in a couple of particle physics books but I can't find any information. Thanks for your help. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| May4-11, 12:04 PM | #2 |
In a sense, you are right, but you'll need to learn about quantum chromodynamic binding energy to get a clearer picture.
| May5-11, 01:36 AM | #3 |
There was an old discussion on this issue here which you might find illuminating.
| May5-11, 11:46 AM | #4 |
Thanks.
| May5-11, 12:39 PM | #5 |
I found http://nohiggs.wordpress.com/2010/06...s-calculation/
mass of a hadron is equal to the sum of its quark masses minus a mass equivalent to the binding energy between them but then also The binding energy of quarks inside the hadrons is a major component of the composite’s particle mass, on top of the masses of the quarks composing it I don't get it. Minus or on top of it (which would be plus!)??? |
| May5-11, 03:24 PM | #6 |
Ok, the mass of a bound state of two particles is smaller than the mass of the two particles if they were free. It's of course because of binding energy.
Why on earth do some people then say that binding energy explains most of the mass of hadrons? that makes no sense |
| May6-11, 01:44 AM | #7 |
* In the normal vacuum; if you put things into a different phase, different things come out. |
| May6-11, 01:48 AM | #8 |
Look here in this thread at post 15 or in this thread post 3, same story.
Why do people here keep saying that 98 percent of the mass of proton comes from binding energy??? That just dead wrong! |
| May6-11, 01:50 AM | #9 |
| May6-11, 01:55 AM | #10 |
Recognitions:
Quarks and gluons inside the proton have kinetic energy which contributes to the mass as well. In a full QCD treatment it's difficult to talk about contributions like free quarks with masses, kinetic energy, potential energy / binding energy; all what one can say is that it's NOT the quark mass term which dominates the mass of the proton.
| May6-11, 02:18 AM | #11 |
Here another dicussion where that is confused. I think the last poster got it right. (At least it sounds right to me!) |
| May6-11, 04:36 AM | #12 |
Is it do with the fact that the force holding quarks together increases as the distance between the quarks increases?
Also, the guy who you are quoting is wrong about the gluons, gluons are massless! |
| May6-11, 06:14 AM | #13 |
Ok, here should be then the true story of the origin of mass. (Or, more precise most of mass!) He explains how you get mass, even if you assume that the quarks are massless. You can have a theory with massless particles as building blocks for a massive particle. Why? Because of m=E/c^2 and asymptotic freedom! |
| May6-11, 09:17 AM | #14 |
Has anything to do the dimension oh radius of compaund via Coulomb and Newton laws about the energy that binding the components, and conseguently via m=E/C^2 ,in the mass??
| May6-11, 09:38 AM | #15 |
Recognitions:
Has anybody ever seen a QCD Hamiltonian? Have you every tried to calculate the different contributions? Have you ever tried to write down a mathemaical expression for "quark-gluon binding energy"? It's not QM, it's QFT. Some of these concepts become (nearly) meaningless.
| New Reply |
| Thread Tools | |
Similar Threads for: Why is the proton so heavy?
| photon-proton/ proton-electron interactions | Quantum Physics | 34 | ||
| Proton-proton collision and virtual photons | Advanced Physics Homework | 0 | ||
| Help me think about Proton-Proton -> Proton+Antiproton collision! | Advanced Physics Homework | 5 | ||
| Collision of a moving proton into a proton at rest (relativity) | Introductory Physics Homework | 13 | ||
| Why homologous proton don't split signal of each other in proton nmr? | Chemistry | 2 | ||
