Hot electronics/computers run hotter?
  • Thread starter Thread starter Pengwuino
    Hot
The discussion revolves around the heat generation of computers and electronics, particularly whether they produce additional heat when operating at higher temperatures, while considering factors like cooling efficiency and airflow. The scope includes theoretical considerations and practical experiences related to computer cooling systems.
  • Experimental/applied
  • Some participants propose that as electronics heat up, their efficiency decreases, leading to increased heat generation in a feedback loop.
  • Others express skepticism about whether a computer generates extra heat solely due to high operating temperatures, suggesting that inefficiencies in cooling systems or airflow obstructions are more likely causes of overheating.
  • A participant shares a personal experience with a computer overheating due to a loose heat sink and emphasizes the importance of proper cooling maintenance.
  • One participant questions the overall contribution of their computer as a heat source in their home environment, particularly in relation to air conditioning challenges.
  • Another participant wonders if improving their water cooling system would help reduce waste heat from their computer.
Participants do not reach a consensus; there are multiple competing views regarding the relationship between operating temperature and heat generation, as well as the effectiveness of cooling systems.
Some claims depend on specific conditions such as the efficiency of cooling systems and the presence of airflow obstructions, which are not universally applicable. The discussion also reflects personal experiences that may not generalize to all systems.
Individuals interested in computer hardware, cooling solutions, and thermal management in electronics may find this discussion relevant.
Pengwuino
My title is a bit lacking, I know! So computers and electronics are typically creating waste heat and are ventilated out, sometimes not so efficiently. However, I was wondering if a computer or router or something actually generates extra heat simply because it is running hot, all other things considered constant?
Computer science news on Phys.org
Yep, the hotter the electronics get, the less efficient the become, generating more heat in the process. A nice positive feedback cycle.
Hmm I wonder how noticeable it is for a computer.
I doubt it. If a computer or other component is running outside of its normal temperature range, it's probably because the cooling fans or heat sinks aren't working at their best or there are fur balls or other stuff blocking airflow, or similar problems. I had some problems with my home computer a couple of summers ago, and discovered that the CPU was running hot, causing a louder than usual fan noise to come on almost continuously. When I opened up the case, I found that the heat sink/CPU fan had come loose, so I took the heat sink off, cleaned the conducting gel off the CPU, put a new coat of gel back on, and put the heat sink/fan back on. The computer's been running fine since then.
My system is water-cooled so that's not really my problem. I'm just wondering if a better water cooling system would reduce the computer's waste heat. Our A/C has a tough enough problem cooling the upstairs, so I'm just wondering how to make it a little easier to cool the upstairs down.
Then again I'm wondering how much of a heat source my computer is in the first place :P
  • · Replies 67 ·
  • · Replies 80 ·
