Number of ways to choose N integers that sum up to X
  • Context: Undergrad
  • Thread starter Thread starter mnb96
    Integers Sum
The discussion focuses on calculating the number of ways to choose N positive integers that sum to a fixed positive integer X. For N=1, there is only 1 way; for N=2, the result is X-1; and for N=3, the formula is (X-1)(X-2)/2. For N greater than 3, generating functions can be employed to derive the number of combinations, leading to the conclusion that the number of permutations is given by the formula {X-1 \choose N-1}. This problem is analogous to placing r indistinguishable balls into n distinguishable boxes, where the formula is {r-1 \choose n-1}.
  • Understanding of combinatorial mathematics
  • Familiarity with generating functions
  • Knowledge of binomial coefficients
  • Basic principles of partitioning integers
  • Study generating functions in combinatorics
  • Learn about binomial coefficients and their applications
  • Explore integer partitioning techniques
  • Investigate combinatorial proofs related to permutations and combinations
Mathematicians, students of combinatorics, and anyone interested in solving problems related to integer partitions and permutations.
mnb96
Hello,
is there a straightforward way, or some well-known expression to count how many ways there are of choosing N positive integers [itex]a_1,\ldots,a_N[/itex] such that [itex]a_1+\ldots+a_N = X[/itex] (where X is some fixed positive integer).
Note that if N=2, and X=10 (for example), I consider the pairs 1+9 and 9+1 (for instance), as being two different ways of obtaining X=10, as well as 2+8 and 8+2, or 3+7 and 7+3, and so on...
For N=1 there is obviously only 1 choice.
For N=2 the result should be: X-1 ways.
For N=3 it is (X-1)(X-2)/2
...For N>3 things get more complicated...
You could use a "generating functions" to find the number of combinations of integers that sum to a given number. Then you might be able to infer the number of permutations from that answer. A search for "generating functions ways of making change" turns up many expositions, for example this PDF explains it: http://ocw.mit.edu/courses/mathematics/18-310c-principles-of-applied-mathematics-fall-2007/lecture-notes/22_2_ln.pdf
If anyone knows a way to use generating functions to get the answer for the number of permutations directly, I'd like to hear about it.
The answer is: [tex]{X-1 \choose N-1}[/tex]
This problem is related to the following:
The number of ways to place r indistinguishable balls into n distinguishable boxes such that no box is empty is given by
[tex]{r-1 \choose n-1}[/tex]
See:
http://msor.victoria.ac.nz/twiki/pub/Courses/MATH261_2011T1/WebHome/notes_2.pdf"
To understand the formula we consider 10 balls:
o o o o o o o o o o
Suppose we are interested in how many ways we can represent 10 as a sum of 3 variables:
a1 + a2 + a3 = 10
We can model this by dividing the 10 balls into 3 blocks, for example:
o o o | o o | o o o o o
Obviously, we need 2 dividers to form 3 blocks. All we need to do is count the number of ways we can place
the dividers between the balls. For 10 balls there are 9 spaces between the balls. Thus, there are 9 positions for the 2 dividers yielding
[tex]{9 \choose 2}[/tex] possibilities.
Summary:
r=10 balls, n=3 blocks
=> r-1 positions for n-1 dividers
possibilities: [tex]{r-1 \choose n-1} = {9 \choose 2}[/tex]
  • · Replies 25 ·
  • · Replies 33 ·
  • · Replies 26 ·
