New Reply
Vectors
Share Thread Thread Tools
May6-11, 06:36 PM   #1
Vectors
Show that is u ≠ 0 and au = bu, then a=b. Here u is a vector and a and b are real numbers
2. Relevant equations
3. The attempt at a solution
I don't see how this is possible. Maybe is it said If A=B and u ≠ 0 then au = bu. If a and b are different then they are just going to scale. The only way I can think of is just dividing by u on both sides but this seems to easy.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May6-11, 07:54 PM   #2
Mentor
Quote by topgear View Post
Division by vectors is not defined.
You're given that u0 and that au = bu.
That's equivalent to au - bu = 0. Can you think of something you can do to work with the left side of this equation?
May8-11, 08:56 PM   #3
take out u then divide by it?
May8-11, 09:40 PM   #4
Mentor
Vectors
I suppose you mean "factor u out." That's reasonable to do. What isn't reasonable or even valid, as I said before, is dividing by a vector.
May8-11, 09:47 PM   #5
Then how should I make u go away
May8-11, 09:52 PM   #6
Mentor
You can't make u go away. What equation do you get when you do the factoring?
May8-11, 09:53 PM   #7
U(a-b)=0
May8-11, 09:57 PM   #8
Mentor
I would write it as (a - b)u = 0, since I usually write scalar multiples of vectors as kv rather than vk.
So (a - b)u = 0. That can happen if u = 0 (which can't happen in this problem). How else can this happen?
May8-11, 10:00 PM   #9
So that means a-b=0 therefore a=b
May9-11, 12:18 AM   #10
Mentor
Yes.
New Reply
Tags
linear algebra, proof, vectors
Thread Tools
Similar Threads for: Vectors
Thread Forum Replies
Vectors: Given two vectors, find a vector that bisects the angle between the two give Calculus & Beyond Homework 10
What are the units of vectors and dual vectors? Special & General Relativity 23
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
Covariant vectors vs reciprocal vectors Differential Geometry 1
PROOF: Independent vectors and spanning vectors Linear & Abstract Algebra 8
