What Could Be Wrong with My Wave Function Equation?
The wave function for a simple harmonic oscillator at x=0 with a frequency of 40 Hz and amplitude of 3.00 cm is derived using the formula y(x,t) = A cos(kx - wt). The correct parameters are A = 0.03 m, k = 8π, and w = 80π. The error in the initial equation arises from not converting the amplitude to meters and potentially miscalculating the wavelength. The correct wave function is y(x,t) = 0.03 cos(8πx - 80πt).
  • Understanding of wave mechanics and harmonic oscillators
  • Familiarity with wave function equations
  • Knowledge of linear mass density and tension in waves
  • Ability to convert units, specifically between centimeters and meters
  • Review the derivation of wave functions in physics
  • Study the relationship between frequency, wavelength, and wave speed
  • Learn about the effects of tension and mass density on wave propagation
  • Practice unit conversions in physics problems
Students of physics, educators teaching wave mechanics, and anyone involved in understanding wave equations and harmonic motion.
lina29
A simple, harmonic oscillator at the point x=0 generates a wave on a rope. The oscillator operates at a frequency of 40 Hz and with an amplitude of 3.00 cm. The rope has a linear mass density of 50.0 g/m and is stretched with a tension of 4.50 N.
Write the wave function y(x,t) for the wave moving in +x-direction. Assume that the oscillator has its maximum upward displacement at time t=0.
I know to write the wave function I use the equation y(x,t)=Acos(kx-wt)
where A=3, k=2pi/[tex]\lambda[/tex]=8pi, w=2pif=80pi
So I got the equation y(x,t)=3cos(8pi x-80pi t)
However when I put it in it says the equation is wrong
Can anyone help me in figuring out what I missed?
Thanks
How did you calculate the wavelength?
Make sure the amplitude is in meters, so 0.03 should be the amplitude
