Real integral using complex variables
The discussion centers around evaluating the integral \(\int_{0}^{\infty }\frac{dx}{1+x^{5}}\) using techniques from complex variables, particularly the residue theorem. Participants are exploring methods to extend the integral into the complex plane and consider various contour integrations.
  • Participants discuss using residues and contour integration, considering different paths such as semi-circles and sectors. There are attempts to combine integrals and explore the implications of symmetry and orientation in the complex plane.
Some participants have provided guidance on combining integrals and suggested alternative paths for integration. There are ongoing questions regarding the correct application of residue calculations and the orientation of integrals along different paths. Multiple interpretations of the approach are being explored.
Participants note potential issues with the orientation of integrals and the calculation of residues, indicating that some assumptions about the behavior of the integrals may need to be revisited. There is a reference to a general formula for integrals of the form \(\int^{\infty}_0 \frac{1}{1+x^n} dx\), which may influence the discussion.
Grothard
[tex]\int_{0}^{\infty }\frac{dx}{1+x^{5}}[/tex]
The attempt at a solution
This is for my complex variables class, so I have been trying to compute it using residues. I noticed that if we extend it to the complex plane and integrate over the edges of a half disk or a quarter disk (or even 3/4 of a disk) of radius R, as R approaches infinity the circular curve part approaches zero. This means that
[tex]\int_{0}^{\infty }\frac{dx}{1+x^{5}} + \int_{0}^{\infty }\frac{dx}{1+ix^{5}} = Res(enclosed)[/tex]
and
[tex]\int_{0}^{\infty }\frac{dx}{1+x^{5}} + \int_{0}^{\infty }\frac{dx}{1-ix^{5}} = Res(enclosed)[/tex]
The residues aren't hard to compute, but I don't know what to do with the other integral
Well, if you add those two equations you can put the complex integrals together to get the integral of 2/(1+x^10). And that you can do with the residue theorem. There may be an easier way to do this, but it's not coming to me right now.
Or, you can add those two equations, then use the fact that 1 + (-x)^5 = 1 - x^5 to make the integral over (-inf,inf).
Instead of a semi-circle, or a quarter, try integrating along the sector with angle [itex]\frac{2\pi}{5}[/itex]. Then the integral along the other straight side should look familiar to you, and the contribution from the arc still goes to zero in the limit.
EDIT: In fact, it is instructive to prove something more general: [tex]\int^{\infty}_0 \frac{1}{1+x^n} dx = \frac{ \pi \csc (\pi/n)}{n}[/tex], where you use the sector with angle [itex]2\pi/n[/itex].
That should work, thanks!
Actually, I am still running into some problems.
Along the other straight side the x term can be expressed as [tex]x = re^{2\pi/n}[/tex] where r is the distance from the origin. Clearly [tex]\frac{1}{1+x^{n}} = \frac{1}{1+r^{n}}[/tex], so integrating the side from 0 to R with respect to r will result in the same integral as the other side.
The problem is that since this is an oriented closed curve, we should be integrating the other way (from R to 0), which would make the integral negative and the two sides would cancel.
Aside from that, something is wrong with my calculation of the residue at [tex]e^{i\frac{\pi }{5}}[/tex]. I factor the polynomial and remove the [tex]\frac{1}{(x - e^{i\frac{\pi }{5}})}[/tex], but I end up with this:
http://www.wolframalpha.com/input/?...i/5)-e^(i*7*pi/5))*(e^(i*pi/5)-e^(i*9*pi/5))]
which I can't see becoming the form of the answer you mentioned
The integrals don't quite cancel (that would be useless for us!). So the integral along the real axis is [tex]\int^R_0 \frac{1}{1+x^n} dx[/tex] and no other work needed, its already in a kind of "simple" form we want. The integral along the other side (account for the negative factor in changing directions) is [tex]- \int_{\gamma} \frac{1}{1+z^n} dz[/tex] where the path is [tex]\gamma(t) = t \cdot e^{2i\pi/n}[/tex] and t varies from 0 to R.
You need to apply this formula correctly:
If the contour C(t) has t range from a to b, then [tex]\int_{C} f(z) dz = \int^b_a f(C(t)) C'(t) dt[/tex]. It won't be precisely the same integral as along the real axis, but it will be some multiple of it (because of the C'(t) term), which is good.
As for your residue calculation (I'll keep on being general using n instead of n=5 ), for some reason I see people going through a heap of grief over computing simple residues. Many things you learned in calculus are still valid here, such as l'hospital's rule! It makes most residue calculations a piece of cake. For example here, the residue at [tex]z= e^{i\pi/n}[/tex] is given by this limit: [tex]L = \lim_{z\to e^{i\pi /n}} \frac{ z - e^{i\pi/n} }{1+z^n}[/tex]. This is clearly of the 0/0 form (if the numerator and the denominator didn't tend to 0, this wouldn't be a residue calculation!) so just using l'hospital's rule simplifies it greatly: [tex]L = \lim_{z\to e^{i\pi/n} } \frac{1}{nz^{n-1}} = \frac{1}{n} \lim_{z\to e^{i\pi/n} } \frac{z}{z^n}[/tex]. I wrote the last inequality in that way because z^n just tends to -1.
