Polarised Window Filters: Block Light from All Directions?
  • Context: Undergrad
  • Thread starter Thread starter MIKEBROCK
    Windows
The discussion revolves around the feasibility of using two polarizing filters sandwiched between glass sheets to control light transmission through a window. Participants explore the implications of this setup, including its effectiveness from various angles of incidence and comparisons to existing technologies like liquid crystal displays and ND filters.
  • One participant proposes a system using two polarizing filters at 90 degrees to each other, suggesting it could allow for adjustable light transmission through a window.
  • Another participant questions the concept of "the polarizing lens" and discusses how the angle of incidence affects light transmission, suggesting that the setup could achieve varying levels of light transmission.
  • A third participant mentions that polarizers work at restricted angles, implying that the proposed system may not function effectively as an everyday window due to this limitation.
  • Some participants suggest that using standard window shades might be a simpler solution compared to the proposed polarizing filter system.
  • There is a discussion about the effectiveness of ND filters, with one participant clarifying that ND filters block light evenly and could serve as an alternative to the polarizing setup.
  • Another participant argues that the incident angle may not significantly impact the effectiveness of the polarizing filters, citing personal experimentation with 3D glasses.
  • Concerns are raised about the dependence of liquid crystal technology on the angle of incidence, contrasting it with the proposed polarizing filter system.
Participants express differing views on the effectiveness of the proposed polarizing filter system, particularly regarding the impact of the angle of incidence on light transmission. Some suggest it may not work well as a standard window, while others believe it could be effective. There is no consensus on the best approach to achieving adjustable light transmission.
Participants mention limitations related to the angle of incidence and the effectiveness of polarizers versus ND filters. The discussion includes references to existing technologies, such as liquid crystal displays, which may have different performance characteristics based on viewing angles.
MIKEBROCK
Would it be possible to use 2 sheets of glass as a window, within the 2 sheets of glass are 2 polarising filters, acting as blinds sandwiched in the glass, at 90degrees from each other. By remote the polarised lens can ascend or descend up and down the window blocking light at different levels. Letting no light come through the window, and only a bit of light through window or all light. Would this work from all directions outside the window?
Science news on Phys.org
I don't understand what "the polarizing lens" is supposed to be. If you have a circular window and there are two polarizing foils of which you can turn one, then you should be able to adjust the transmission between close to 45% and 0% because the first foil will cut out half of the light, and the window reflects about 4%. The incidence angle should not matter much, but you may see that you can suppress or enhance light that is reflected of clean surfaces like puddles since that tends to be polarized. With two 90 degree foils and a third one that you can turn in between for "magic transmission" at 45 degrees, you will be able to adjust the light intensity between under 3% and 0%
That is pretty dark.
Transmissions (maximum case):
window 96%
polarizer 50%
45 deg polarizer 25%
polarizer 25%
window 96%
Polarizers generally work at restricted angles of incidence, so the effect would only be partial. Kent State's Liquid Crystal Institute developed a similar device- the transmission was controlled by altering the retardance of a thin liquid crystal layer, and could be switched very rapidly:
http://www.lci.kent.edu/switch.html
IIRC, the technology has been adapted for welding glasses.
It's much easier just to use a standard window shade.
thanks for the help, and sorry for the very late reply. So it would not be possible as an everyday window due to the variation in incidence angle? Seems to be a conflict in answers here, thank you anyway.
Again, I do not think that the incident angle matters much. Just get two pairs of 3D glasses and hold them over one another such that all light is blocked. (you might have to flip the direction) I do not think you get light through even at low angles. Liquid crystals are another matter, there the incidence angle matters much more as you see with TFT displays.
I think the polarization is the least of your problems. The way you describe it, you have the same effect just with an ND filter and much cheaper at that.
ok thankyou, good idea i will try that. Do ND filters block all light though?
ND Filters block all light evenly, they are basically shades.
Even with displays, it depends on the technology. Good LCD panels are pretty much angle-independent. Only the inexpensive (TN) panels have substantial changes with viewing angle.
9K
  • · Replies 24 ·
  • · Replies 19 ·
14K
