Does spin change under Lorentz boosts?
  • Context: Graduate
  • Thread starter Thread starter QuantumCosmo
    Change Lorentz Spin
The discussion centers on the behavior of particle spin under Lorentz boosts, specifically addressing whether the spin magnitude, represented by S², commutes with the generators of Lorentz boosts. It is established that S² remains invariant across all reference frames, confirming that an electron retains its spin-1/2 characteristic universally. However, the orientation of spin, such as S_z, does change with Lorentz boosts, as demonstrated by the non-commutation of S_z with the boost generators. The Pauli-Lubanski operator W is introduced as a more appropriate tool for analyzing spin in moving frames.
  • Understanding of Lorentz transformations and boosts
  • Familiarity with quantum mechanics concepts, particularly spin and angular momentum
  • Knowledge of the Pauli-Lubanski operator and its significance in relativistic quantum mechanics
  • Basic grasp of commutation relations in quantum mechanics
  • Study the properties of the Pauli-Lubanski operator W in detail
  • Research the implications of spin in relativistic quantum mechanics
  • Explore the mathematical framework of Lorentz transformations and their effects on quantum states
  • Investigate the relationship between spin and rotation in quantum systems
Physicists, particularly those specializing in quantum mechanics and relativistic physics, as well as students seeking to deepen their understanding of spin behavior under Lorentz boosts.
QuantumCosmo
Hi,
I was wondering if the spin of a particle changed under Lorentz boosts. I think what it comes down to is if S^2 commutes with the generators of Lorentz boosts (the components of S only generate the rotations of the spinor I think). I think that should be true (an electron should always be a spin 1/2 particle in every coordinate system). So I hope S^2 commutes with those generators?
The next question is: What about the spin direction? Take S_z for example. Does S_z commute with the generators of Lorentz boosts? If an electron has spin up in one coordinate system, does it have spin up in all others too?
(For rotations that is obviously not true. If we rotate the system around the x axis, a particle that was previously characterized by spin in the z direction will now have a component in the y direction too because S_z and S_x don't commute)
Thank you,
QuantumCosmo
Spin orientation does change, but spin 1/2 which should better read S² = 1/2 * (1/2 + 1) = 3/4 is valid in all reference frames. This due the fact that the S² is something like the second Casimir (p²=m² is the first) and therefore commutes with all Lorentz generators. More exactly, one has to use the Pauli-Lubanski operator W instead of S; for W one finds W² = -m² s (s+1) which is a c-number.
http://en.wikipedia.org/wiki/Pauli-lubanski_pseudovector
Note that it is not straightforward to interpret the Pauli-Lubanski vector as a spin vector when the particle is moving. Wμ is orthogonal to Pμ in the four-dimensional sense, so for a moving particle Wμ will have a time component. And of course the three space components (Wx, Wy, Wz) taken by themselves won't have the expected norm.
  • · Replies 17 ·
