The discussion revolves around the possibility of calculating water pressure using only the flow rate in gallons per minute (gpm) and the inside diameter of a hose in inches. Participants explore the relationship between flow rate, pressure, and other factors in fluid dynamics.
- Exploratory, Technical explanation, Debate/contested
- One participant suggests that more information is needed to calculate the pressure of water leaving the hose.
- Another participant proposes that Bernoulli's equation could be relevant to the discussion.
- A different participant mentions that the pressure after the water leaves the hose is assumed to be atmospheric pressure, but the pressure against a surface can be calculated using the force of the water divided by the cross-sectional area of the stream.
- One participant discusses calculating force exerted during high-pressure water blasting, providing specific values for pump pressure and flow rate, and seeks help with back pressure calculations.
- Another participant emphasizes the need to determine the velocity of the water to apply Bernoulli's equation, asking for the area of the nozzle.
- A later reply clarifies that there are two nozzles, both with a diameter of 1/8".
Participants express differing views on whether the information provided is sufficient to calculate pressure, with some suggesting that additional parameters are necessary while others propose methods to derive pressure from the given data.
There are assumptions regarding the relationship between pressure, flow rate, and velocity that remain unresolved. The discussion does not clarify the specific conditions under which the calculations would apply.
Individuals interested in fluid dynamics, engineering applications involving water pressure, and those seeking to understand the principles behind pressure calculations in practical scenarios may find this discussion relevant.
