Finding the Mass of a Second Block in a Spring Equilibrium Problem
  • Thread starter Thread starter BlackMamba
    Spring
The problem involves a spring equilibrium scenario where a 0.82 kg block is suspended from a spring, and a second block is added, causing the spring to stretch by a factor of 8. The challenge lies in determining the mass of the second block without a given spring constant.
  • Participants discuss the equilibrium condition of the system and the relationship between forces acting on the blocks and the spring. There is uncertainty about the meaning of the spring stretching by a factor of 8 and how to incorporate that into their equations. Some participants express confusion about the implications of the spring constant and the distance stretched.
Several participants have provided insights into the equations governing the problem, suggesting a division of equations to eliminate variables. There is ongoing exploration of the implications of these equations and how to manipulate them to isolate the mass of the second block. Some participants are clarifying their understanding of the relationships between the variables involved.
Participants note the absence of a spring constant and express concerns about how to proceed with multiple unknowns in their equations. The discussion reflects a mix of interpretations regarding the problem setup and the physical meaning of the spring's behavior.
BlackMamba
Hello,
I have a problem that I thought I knew how to figure out but I'm getting a bit stuck. Here's the problem:
A 0.82kg block is hung from and stretches a spring that is attached to the ceiling. A second block is attached to the first one, and the amount that the spring stretches from unstrained length increases by a factor of 8. What is the mass of the second block?
My problem is that there isn't a spring constant given here.
I would guess that once the second block has been added, the two blocks aren't going up and down or oscillating. So that would make this problem an equilibrium one.
In that case I know that F = W ------ F = kx and W = mg
I's assuming that x is 8 but that doesn't make sense to me since that isn't 8 really isn't a distance. At least I don't think it is...
Anyway, I'm just lost..Any help would be greatly appreciated.
Make the formulas for the data in case 1, and then in case 2.
Ok, let's see...
The first case the block is just hanging there. Mass is 0.82. That's all I know about the first case. If I drew a force diagram I would have the weight force pointing down and the spring force pointing up. I just mentioned earleir that [itex]F = W[/itex] Which is also written as [itex]kx = mg[/itex]. If I drew my origin at the point where the spring and the block meet that would make x = 0...right?? So the only thing in play for the first case is the blocks mass times gravity...
In the second case a new block of mass m is added to the already hanging block of mass = 0.82kg. The spring now stretches by a factor of 8. <----(I got to admit I have no idea what that means.) So if I drew a new force diagram for the second case I would have two weight forces pointing down and still one spring force pointing up. It's here that I don't know where to go next.
Am I on the right track here? I'm not sure where I need to be going after the first case.
the first equation is correct. i will rewrite it again here.
[tex]m_{1}g=kx[/tex]
case 2 :
[tex](m_1+m_2)g=k(8x)[/tex] assuming that this phrase 'the spring stretches from unstrained length increases by a factor of 8' indicates the spring stretches by a factor of 8 from the previous one.
OK, for case two, though, how in the world do I solve for that?? I don't know what k or x is and I'm trying to find m2 so how do I solve for an equation which has 3 unknown variables.
divide the two equations to get rid of x and k.
Oh...ok. Thanks for telling me...But I think it would be important for me to know why I would be dividing the equations? I mean, I probably would never have come to that point on my own...well obviously or else I wouldn't be here. lol
Also wouldn't the m1 also cancel out?
Thanks for helping me out.
as what i mentioned just now, you have to divide them to get rid of x and k to find m2. m1 won't be canceled out. you will get :
[tex]\frac{m_1}{m_1+m_2}=\frac{1}{8}[/tex]
or you can see this way : substitute equation 1 into equation 2 and k and x will be gone.
Wow, ok now I am lost...I get now to divide the two equations to get rid of x and k, but where did that 1 come from?
Oh, ok making a substitution makes a little more sense to me. It makes it a bit easier to understand.
Thanks again for your help.
  • · Replies 52 ·
  • · Replies 18 ·
