Diagonalizability dependent on nullity and inner product?
  • Context: Graduate
  • Thread starter Thread starter meboxley
    Inner product Product
The discussion revolves around the diagonalizability of a matrix A expressed as A = U(V^T), where U and V are non-zero vectors in R^n. Participants explore the implications of nullity, inner products, and eigenvalues in determining whether A can be diagonalized.
  • One participant has proven that U is an eigenvector of A with the corresponding eigenvalue being the inner product of U and V.
  • The same participant confirmed that the nullity of A is n-1, suggesting that the rank of A is 1, which implies the existence of n-1 linearly independent eigenvectors corresponding to the zero eigenvalue.
  • Another participant suggests that to establish diagonalizability, one more linearly independent eigenvector with a non-zero eigenvalue is needed, which they argue can be derived from the eigenvector U.
  • A different participant questions the diagonalizability of a specific matrix example (UV^T) and implies that the original question may have been misunderstood.
  • One participant points out that the assumption of U and V being non-orthogonal is crucial, as it ensures that U has a non-zero eigenvalue.
There is no consensus on the diagonalizability of matrix A. While some participants agree on the implications of nullity and the need for additional eigenvectors, others raise concerns about specific cases and assumptions that may affect the conclusion.
Participants have not fully resolved the implications of the orthogonality of U and V, nor have they clarified the conditions under which the matrix A is diagonalizable. The discussion includes varying interpretations of the requirements for diagonalizability based on the properties of eigenvalues and eigenvectors.
meboxley
Hello everyone!
I am doing some work involves proving that a matrix A (A=U(V^T)) is diagonalizable. In this situation, U and V are non zero vectors in R^n.
So far, I have proven that U is an eigenvector for A, and that the corresponding eigenvalue is the inner product of U and V ((U^T)V). [Here I multiplied both sides by U and then did some simple equation manipulations.] Also, I have confirmed that the nullity of A = n-1 (via proof that rank(A)=1). [Since the rows of A are multiples of the rows of V^T, then the row space of A has dimension 1 --> rank(A)=1.]
I know that I need to use the things that I have already proven, and I also know that U(dot)V cannot equal zero. However, I am a bit stuck on how the information that I have constructed already shows that A will have n linearly independent eigenvectors. (I have also already done enough work to see that this is the only condition possible to be proven that implies that A is diagonalizable - I think!)
Any help with connecting all of this would be great! Thanks!
You're pretty much there. The nullity is the dimension of the kernel, the set of vectors annihilated by the matrix: in other words, the set of eigenvectors with zero eigenvalue. Since the nullity is n-1, you have n-1 linearly independent zero eigenvectors. You just need one more LI eigenvector to span the space, and any eigenvector with nonzero eigenvalue must by LI of the kernel. And you've got such an eigenvector, so you're done.
What about
[tex]UV^T=\left(\begin{array}{c} 1\\ 0\end{array}\right)\left(\begin{array}{cc} 0 & 1\end{array}\right)=\left(\begin{array}{cc} 0 & 1\\ 0 & 0\end{array}\right)[/tex]?
This is not a diagonalizable matrix. Or did I misunderstand your question?
Hidden in the OP is the assumption that U and V are not orthogonal, and this is sufficient. It guarantees that U has a nonzero e'value.
