Are the definitions of vector in Linear Algebra and physics compatible?
The discussion revolves around the compatibility of vector definitions in linear algebra and physics, particularly in the context of relativity and tensor analysis. Participants explore the implications of coordinate transformations and the nature of vectors and coordinates in both fields.
  • One participant expresses confusion about whether coordinates can be considered vectors, citing a transformation example that seems to contradict the physics definition of contravectors.
  • Another participant emphasizes the need for precision in defining Rn, noting that it can represent different concepts depending on context, such as polar coordinates or Cartesian coordinates.
  • A third participant mentions the relationship between covectors and vectors, suggesting that physicists have different formulas for variable changes compared to mathematicians.
  • Another viewpoint suggests that Rn is not inherently a vector space without the structure of scalar multiplication and addition, and discusses the common practice of blurring the distinction between the set of vectors and the vector space structure.
  • One participant notes that in physics, the term "vector" often refers to tangent vectors associated with manifolds, while other types of vectors may receive different names.
Participants do not reach a consensus on the compatibility of vector definitions in linear algebra and physics. Multiple competing views and interpretations remain, particularly regarding the nature of coordinates and their classification as vectors.
Participants highlight limitations in definitions and assumptions, such as the nature of coordinate transformations and the structure required to define a vector space. The discussion reflects the complexity of terminology and concepts across mathematics and physics.
This discussion may be of interest to students and professionals in physics, mathematics, and engineering, particularly those exploring the relationship between linear algebra and physics concepts like tensors and manifolds.
MManuel Abad
I'm really confused. I study physics, and in Relativity we deal a lot with vectors and tensors.
I know an element x of Rn is a vector, because Rn is a vector space. That's fine.
Now, in physics, we define a (contra-) vector xa (with 'a' an index running from 1 to n) as a n-tuple of quantities Va that, under a coordinates transformation from x to x' given by:
[tex]x^{a}\rightarrow x'^{a}=x'^{a}\left(x^{1},x^{2},...,x^{n}\right)[/tex]
transform as:
[tex]V^{a}\rightarrow V'^{a}=V^{b}\frac{\partial x'^{a}}{\partial x'^{b}}[/tex]
where Einstein summation convention is used.
Everything is fine... 'till the question: ¿Are coordinates (cartesian, if you like) vectors?
A coordinate is an element of Rn so, as the definition of Linear Algebra says, YES, coordinates are vectors.
But let's see if that is so in physics.
Let's consider the simplest coordinate transformation: that of adding a constant cato each coordinate:
[tex]x^{a}\rightarrow x'^{a}=x^{a}+c^{a}[/tex]
Then, it's easy to see that, using physics definition, the coordinates xa are not vectors (at least, not contra-vectors), 'cuz the expresion
[tex]\frac{\partial x'^{a}}{\partial x'^{b}}[/tex]
gives 1 if a=b and 0 if a=/=b, so the definition would say:
[tex]x'^{a}=x^{a}[/tex]
which, obviously, is not true.
¿So, what? Actually, I've never seen, in Relativity books, that the author calls the xa contravectors. But even physicists call them a "Radio vector". What's going on? But I've seen that the differentials dxa ARE contravectors (The physics definition works with the transformation I've used).
Could someone explain it to me? Are the definitions of vectors in Liner Algebra and physics contradictory?
I'm not a an expert of the use of tensors in physics, but I'll make the following observations.
You have to be precise about what you mean by [itex]R_n[/itex]. For example, if [itex]R_2 [/tex] simply means pairs of real numbers then there is no implied operation to add two members of [itex]R_2 [/tex] together. For example (a,b) might be the polar coordinates of a point on the plane, or it might be the cartesian coordinates of a point on the plane or it might be someone's height and weight. <br /> <br /> You example uses translation as a change of coordinates. In many contexts, a change of coordinates is assumed to be represented as multiplication by an invertible matrix. In 2 dimensional, cartesian coordinates for the plane, translation can't be represented as multiplication by a matrix. To use a matrix, you can represent a point (x,y) in the plane as (x,y,1) in "homogeneous" or "projective coordinates". Then<br /> <br /> [tex]\begin{bmatrix} 1 & 0 & c \\ 0 & 1 & c \\ 0 & 0 & 1 \end{bmatrix} \begin{bmatrix} x \\ y \\ 1 \end{bmatrix} = \begin{bmatrix} x + c \\ y + c \\ 1 \end{bmatrix}[/tex][/itex][/itex]
The covectors constitute the dual space of the vectors. This tells mathematicians how to treat them when you change variables. Physicists have these weird formulas to use for that... Why? You'll have to ask a physicist.
One way to look at it is, as Stephen suggests: Rn, the set of tuples (finite lists) of n real numbers isn't itself a vector space; it's just a set. Only with the extra structure of scalar multiplication and componentwise addition do we construct a vector space using this set for its vectors. The usual way to express this idea is to say that the famous vector space is itself a tuple (Rn,K,+,s), where K is the field of real numbers with the usual definitions of addition and multiplication, + is vector addition and s the scalar multiplication function (multiplying a vector by a real number). Because one kind of addition and one kind of scalar multiplication are so standard, and such natural choices, the common practice is to blur the distinction between the set of vectors and the extra structure that makes it into a vector space, and to speak as if the underlying set was itself the vector space.
Another way to look at it would be to say, okay, coordinates are vectors in Rn (although, in this application, depending on the coordinate system, we don't necessarily use the full vector machinery), but, in physics, the unqualified word vector, by tradition, tends to refer to a vector of the tangent space associated with some point of a manifold representing space or spacetime. Vectors of other vector spaces tend to be given some other name or qualification, relating them to tangent vectors, such as covectors, tensors, etc.
Wow, thanks, that really helped. I'm thinking I'm going to study diff. geometry, and try to understand what's all of that: manifolds, tangent spaces and stuff. Thank you all :)
  • · Replies 0 ·
  • · Replies 27 ·
