Parametric equations for a particle
The problem involves analyzing the motion of a particle described by parametric equations for its x and y coordinates as functions of time t. Participants are tasked with finding points where the velocity in the x direction is zero, calculating the derivative dy/dx at a specific time, and determining the second derivative d²y/dx² under certain conditions.
  • Participants discuss the conditions under which the velocity in the x direction is zero and whether this corresponds to horizontal tangents. There is also a focus on differentiating the parametric equations to find dy/dx and d²y/dx².
Some participants have provided calculations for the first derivative and questioned the nature of tangents at points where the x-velocity is zero. There is ongoing exploration of the implications of these findings, particularly regarding the existence of horizontal tangents and the interpretation of the derivatives.
There is a noted constraint that t must be greater than zero, which affects the calculations and interpretations of the results. Additionally, there is some confusion regarding the correct interpretation of the parametric equations.
rjs123
The path of a particle is given for time t > 0 by the parametric equations: x = t +2/t, y = 3t^2
a. Find the coordinates of each point on the path where the velocity of the particle in the x direction is zero.
b. Find dy/dx when t = 1
c. Find d^2y/dx^2 when y = 12
a. No horizontal tangents...dy/dt = 6t...= 0 when t = 0...but t must be greater than 0 (condition)
b. dy/dx = (dy/dt)/(dx/dt) = 6t/(1-2/t^2) = -6...when you plug in 1
c. stuck on c at the moment
For a) you want to get were dx/dt = 0 and then rearrange for t. This will give a value for t, so you can get the x and y coordinates for it.
b) is correct.
For part c, differentiate the expression wrt t using implicit differentiation, can you do this?
a. dx/dt = 1 - 2/t^2 = 0
1 = 2/t^2
1/2 = t^2
t = sqrt(1/2)
x = 3.5355, y = 1.5
this is what i got for your recommendation.
1 = 2/t^2
1/2 = t^2
t = sqrt(1/2)
x = 3.5355, y = 1.5
I thought when the velocity of the particle in the x direction is zero when there is a horizontal tangent present?
The gradient function of x is dx/dt. So if dx/dt = 0 (or the velocity in the x-direction is zero), then the tangent drawn has a zero gradient i.e. is a horizontal tangent.
yes, the graph has no points where there could be a horizontal tangent line...the one found on your recommendation contains a slope of -2...at (3.5, 1.5)
if x = t + 2/t had no stationary points then putting dx/dt = 0 would lead to something like 0=2.
However there would be a slope since the vertical velocity is not zero at t = 1.
Is x= t+ (2/t) or (t+2)/t?
For (a): If the velocity in the x direction is zero, then the tangent to the path is vertical, not horizontal.
For (c):
[tex]\frac{d^2y}{dx^2}=\frac{d\left(dy/dx\right)}{dx}=\frac{d\left(dy/dx\right)/dt}{dx/dt}[/tex]​
and you found that
[tex]\frac{dy}{dx}=\frac{6t}{1-2t^{-2}}[/tex]​
  • · Replies 20 ·
