Solving Part C of Jerry's Skateboard Problem
  • Thread starter Thread starter butz3
    Skateboard
The discussion focuses on solving part C of Jerry's Skateboard Problem, which involves calculating the work done by Jerry when he jumps off the skateboard. The relevant formulas include the Work-Energy Theorem and the kinetic energy equations. Jerry's initial speed at the bottom of the hill is determined to be 6.57 m/s, and the skateboard's velocity after Jerry jumps is calculated to be 16.8 m/s east. The work done by Jerry on the skateboard is found to be 928.93 J, derived from the change in kinetic energy of the system.
  • Understanding of the Work-Energy Theorem
  • Knowledge of kinetic energy calculations (KE = 1/2 mv²)
  • Basic principles of momentum and velocity
  • Familiarity with forces and displacement in physics
  • Study the Work-Energy Theorem in detail
  • Learn about momentum conservation in collisions
  • Explore advanced kinetic energy problems involving multiple objects
  • Investigate real-world applications of work and energy principles
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of work and energy in motion scenarios.
butz3
i need help on how to start to solve part c in a 3 part question. the question reads "Jerry is stationary on his skateboard at the top of the hill shown in the following diagram. he than rolls from rest down the hill. A) assuming that the hill provides a frictionless surface, determine jerry's speed at the bottom of the hill.
B)when Jarry reaches the horizontal surface near the bottom of the hill, he jumps off the skateboard so that he ends up moving 5.8m/s in the orginal direction of the skatebaord. what is the resulting velocity of the skateboard?
C)how much work does jerry do on the skateboard in order to jump off?" the diagram is that jerry is sitting at the top of the hill it sort of looks like this
-----j\
l \
l \
l \
with 2.2m along the vertical and 5.0m along the horizontal. jerry's mass is 40.0kg and the skatebord's mass is 3.0kg.
for part A) i got jerrys speed as 6.57m/s. part B) i got the velocity of the skatebord as 16.8m/s east. know i know the formula to find work is w=fd. but i don't have a force i guess i could figure that out but what would i use for the distance. or if anybody has a better suggestion on how to solve this problem would be a great help. thanks.
There is more than one way to find the work done. Remember the Work-Energy Theorem. Ask yourself - where does the work Jerry does go?
To solve part C of Jerry's skateboard problem, we need to use the concept of work and energy. Work is defined as the product of force and displacement, and it measures the amount of energy transferred when an object is moved by a force. In this case, we need to find the work done by Jerry on the skateboard when he jumps off.
First, we need to understand that when Jerry jumps off the skateboard, he applies a force on the skateboard in the direction opposite to his motion. This force causes the skateboard to move in the opposite direction with a certain velocity. This change in velocity is what we need to consider when calculating the work done.
To find the work done, we can use the formula W = ΔKE, where W is the work done, ΔKE is the change in kinetic energy, and KE is the kinetic energy of the system. In this case, the system consists of Jerry and the skateboard.
We can find the initial kinetic energy of the system by using the formula KE = 1/2 mv^2, where m is the mass of the system and v is the initial velocity. In this case, the initial velocity is the speed of Jerry at the bottom of the hill, which we have calculated in part A (6.57m/s). The mass of the system is the combined mass of Jerry and the skateboard (40.0kg + 3.0kg = 43.0kg). Therefore, the initial kinetic energy of the system is KE = 1/2 (43.0kg)(6.57m/s)^2 = 979.87 J.
To find the final kinetic energy of the system, we need to consider the change in velocity of the skateboard when Jerry jumps off. We know that Jerry ends up moving with a velocity of 5.8m/s in the original direction of the skateboard. This means that the final velocity of the skateboard must be in the opposite direction with a magnitude of 5.8m/s. Using the formula KE = 1/2 mv^2, we can calculate the final kinetic energy of the system as KE = 1/2 (3.0kg)(5.8m/s)^2 = 50.94 J.
Now, we can find the change in kinetic energy by subtracting the final kinetic energy from the initial kinetic energy. ΔKE = 979.87 J - 50.94 J = 928.93 J.
Therefore,
