Proof (derivatives of sin/cos/tan)
  • Thread starter Thread starter QuarkCharmer
    Proof
The discussion revolves around proving the derivatives of the sine and tangent functions, specifically that the derivative of sin(x) is cos(x) and the derivative of tan(x) is sec^2(x). The participants reference the difference quotient and trigonometric identities as part of their approach.
  • Participants express uncertainty about how to proceed with the proofs and discuss the limits involved in finding these derivatives. Some mention using L'Hopital's rule, while others suggest that the limits can be shown without it. There are questions about the behavior of sin(h)/h as h approaches 0 and the implications of this limit.
The discussion is ongoing, with participants sharing their attempts and insights. Some have provided explanations related to the squeeze theorem and the unit circle to clarify the limit of sin(h)/h. There is no explicit consensus, but several participants are actively engaging with the concepts and helping each other understand the proofs better.
Participants note challenges with LaTeX formatting and the clarity of shared images, which may affect the communication of their attempts. There is also mention of working under fatigue, which could impact their reasoning.
QuarkCharmer
Prove that:
[tex]\frac{d}{dx}sin(x) = cos(x)[/tex]
[tex]\frac{d}{dx}tan(x) = sec^2(x)[/tex]
Difference Quotient, Trig Identities
Not sure how to go about the rest of this?
I haven't attempted the tangent yet, but I will post it here when I do rather than 2 threads.
Edit: Latex for this one a bit over my head, I am uploading a picture...
QuarkCharmer said:
Prove that:
As I recall, there are a couple of limits that come into play when you find the derivatives of these trig functions using the definition of the derivative.
[tex]\lim_{h \to 0} \frac{sin(h)}{h}=1[/tex]
[tex]\lim_{h \to 0} \frac{tan(h)}{h}=1[/tex]
Yeah, L'Hopital's rule. But you have to know that d/dx sin(x) = cos(x), and that's what I'm trying to prove lol.
Either way, I still have something like sin(x) over the delta-x, so I am not sure that applies?
I'm just having a huge headache with these two problems and now I'm doubting the whole thing!
No, these limits can be shown without using L'Hopital's Rule.
Ugh, I think I see an error that I can't believe I made. Working on no sleep here. I'll give it another shot now.
The other limit that is used is
[tex]\lim_{h \to 0} \frac{1 - cos(h)}{h}=0[/tex]
I'm not seeing how sin(h)/h = 1 as h tends to 0. Wouldn't that mean that sin(h) is approaching 1, but it's divided by something approaching zero? I know you can divide this way with limits because it's not 0, it's tending towards 0, but I'm still not seeing it?
sin(h) approaches h as h tends to 0. It might be helpful graph y = sin x and y =x together near x=0.
Here's why lim sinh/h = 1, as h --> 0.
One proof uses the unit circle. Extend a ray from the origin out to and past a point on the circle. The ray should be at a small angle h (in radians) to the x-axis.
The ray intersects the circle at (cos h, sin h). At this point, drop a vertical line down to the x-axis. At (1, 0), draw a vertical line segment up to the ray. That point of intersection is (1, tan h).
The ray defines a small right triangle, a circle sector, and a large right triangle. Looking at the areas, we see that the area of the small triangle <= area of the sector <= area of large triangle.
That is, (1/2) cos(h) sin(h) <= (1/2) h <= (1/2) tan(h), where (1/2) h is the area of the sector.
Equivalently, cos(h) sin(h) <= h <= tan(h), and this is true for h "small" and close to zero.
Divide by sin(h) to get:
cos(h) <= h/sin(h) <= 1/cos(h)
Use the squeeze theorem. cos(h) --> 1 and 1/cos(h) --> 1 as h --> 0, hence lim h/sin(h) = 1, as h --> 0.
Not sure why I wrote sin(h) = 1 as h tends to 0 up there. In my head I was thinking 0, which still leads to a ratio that is approaching 1, but not one. I didn't understand how it could be approaching 1, but the tutoring center here helped me out with that same explanation. Thanks!
I'll try my hand at the same problem for tangent now.
Edit: That is a good squeeze theorem explanation above. I didn't see that post when I submitted this first, but that one is great. Many thanks.
Alright, I think I have this down now. Would you mind looking it over?
Your scanned image is hard to read. The bottom half is fairly clear, but the top half is pretty faint.
Okay, I'll give this a shot:
Pretend there is a limit as h tends to 0 before all this:
[tex]\frac{d}{dx} tan(x) = sec^2(x)[/tex]
[tex]\frac{tan(x+h)-tan(x)}{h} =[/tex]
Here I just gave a common den. and used the tan ident.
[tex]\frac{\frac{tan(x)+tan(h)}{1-tan(x)tan(h)} - \frac{tan(x)(1-tan(x)tan(h))}{1-tan(x)tan(h)}}{h}[/tex]
[tex]\frac{\frac{tan(h)+tan^2(x)tan(h)}{1-tan(x)tan(h)}}{h}[/tex]
[tex]\frac{tan(h)(1+tan^2(x))(1)}{h(1-tan(x)tan(h))}[/tex]
[tex]\frac{tan(h)}{h} \frac{sec^2(x)}{1-tan(x)tan(h)}[/tex]
[tex]\frac{sec^2(x)}{1-0}[/tex]
[tex]sec^2(x) = sec^2(x)[/tex]
I will also pretend that there is an equals between all of these equal expressions.
Somewhere near the end you "passed to the limit" as they say, or took the limit.
[tex]= \lim_{h \to 0}\frac{tan(h)}{h} \frac{sec^2(x)}{1-tan(x)tan(h)}[/tex]
[tex]= \lim_{h \to 0}\frac{tan(h)}{h} \lim_{h \to 0}\frac{sec^2(x)}{1-tan(x)tan(h)}[/tex]
[tex]= 1 \cdot sec^2(x)[/tex]
In the line above the last one, lim tan(h)/h = 1, and lim (sec^2(x))/(1 - tan(x)tan(h)) = sec^2(x), as h --> 0.
Yeah, it wasn't really a "homework" assignment, nobody will read it. I was mostly curious myself more than anything. I really appreciate all of the help. Maybe one day someone will ask something that I can help with and I can repay.
  • · Replies 21 ·
