Capacitance calculation by using conformal mapping
The discussion centers around the calculation of capacitance for a sphere-plane system using conformal mapping. Participants explore the applicability of conformal mapping in this context, considering both theoretical and practical aspects of the problem.
  • Some participants question the use of conformal mapping for a 3D problem, suggesting it is more suited for 2D applications, while others propose that with azimuthal symmetry, it could be adapted to 2D.
  • One participant mentions a theorem stating that capacitance in a 2D system is unaffected by conformal mapping, but expresses uncertainty about its validity in 3D.
  • Another participant notes the limited types of useful conformal mappings available in 3D, such as rotations and translations.
  • A participant references a solution for sphere-plane capacitance found in a textbook, while another seeks a specific conformal mapping to concentric spheres.
  • Some participants discuss the integration methods for calculating capacitance, suggesting that conformal mapping can be applied by revolving the result of the conformal transform.
  • There is a mention of the difficulty in finding the electric field for certain geometries, which complicates the capacitance calculation.
Participants express differing views on the applicability of conformal mapping to the sphere-plane system, with no consensus reached on whether it is a viable method. The discussion remains unresolved regarding the best approach to calculate the capacitance.
There are limitations noted regarding the assumptions made about the applicability of conformal mapping in 3D, as well as the complexity involved in calculating capacitance for non-standard geometries.
asmani
Hi all
How to calculate the capacitance of a sphere-plane system by using conformal mapping?
Thanks
asmani,
just wondering why you would want to use conformal mapping for this. Conformal mapping applies to 2D problems. Your problem looks 3D, although with azimuthal symmetry it can be made 2D. You would have to work out a lot of details to make this work, if it works at all. Sounds painful to me.
An easier approach would be to use images. Now, this is pretty challenging for an image problem, but some textbooks get you most of the way there. Once you understand the solution for a point charge near a conducting sphere, you are most of the way there.
good luck,
jason
hi asmani! :wink:
i don't know much about this …
in goldfish college, we don't have electricity labs, for obvious reasons :redface:
but looking only at the geometry, i wonder whether it would help to make a conformal map onto a pair of concentric spheres? :smile:
Thanks a lot for the replies.
Yes, I think it helps.
Apparently there is a theorem saying that the capacitance of a 2D system is unaffected by a conformal mapping. I'm not sure if this holds in 3D.
I have seen the solution by using the method of images and apparently the capacitance calculated by this method has not a closed form.
As we know, the capacitance of a pair of concentric spheres with radius R1 and R2 has a closed form expression in terms of R1 and R2.
Let's assume the radius of the sphere is R, the distance between its center and the plane is d and the above theorem holds in 3D. If the sphere-plane system is mapped by a conformal mapping to a pair of concentric spheres with radius R1 and R2, then R1 and R2 have not a closed form expression in terms of R and d, unless one of the above assumptions is not true.
The thing is, there's not a lot of useful conformal mappings in 3D . Rotations, translations, uniform scaling, and that's it. Well, you may also include mirroring.
The sphere-plane capacitance is solved on page 131 in Smythe Static and Dynamic Electricity (Third edition).
Bob S
Thanks Bob, I'm looking for the solution by using conformal mapping.
Do you know such a mapping?
sorry, no …
i can't even find anywhere to look it up :redface:
jasonRF said:
asmani,
good luck,
jason
obviously I was wrong ... I learned conformal mapping in complex analysis and have only used for solving 2D problems. This thread, and google, have set me straight. Thanks! I haven't figured out how to solve your problem, though ...
jason
Did you folks not learn about integration of a http://en.wikipedia.org/wiki/Surface_of_revolution" ? Particularly in this case of sphere-plane you have the right symmetry for that. So yes, of course you can use conformal mapping for 3D. Just revolve the result of the conformal transform for the area and use the normals for the distance.
Just go back to the derivation of capacitance for all the standard geometric cases (parallel plate, two wires, etc). The common feature for all: you have integration over area S for the charge and integration of over distance d for the voltage. Then it's just C = Q/V
A little math but not that much really. Should be a no brainer.
Of course we did.
I have no idea what this means ... Could you please explain?
Of course, once you know the potential (or equivalently the electric field) then you just follow the recipe you mentioned. The hard part is finding the field, which is of course the hard part of the OP question. The parallel plate problem is "easy" if you ignore edge effects (which I am guessing is what you are talking about), but if you want to truly solve for the capacitance of two finite parallel plates it is quite difficult to determine the field, and hence the capacitance.
jason
  • · Replies 32 ·
  • · Replies 17 ·
