Can an alternate Muonic Helium model be created with one electron and one muon?
  • Context: Graduate
  • Thread starter Thread starter jfy4
    Helium
The discussion revolves around the proposal of an alternate model for muonic helium, specifically involving a helium nucleus with one electron and one muon. Participants explore the implications of this model, including the mass ratios of the particles and the validity of certain approximations in quantum mechanics.
  • One participant proposes modeling a helium nucleus with one electron and one muon, questioning whether the muon's mass is small enough to approximate a stationary center.
  • Another participant suggests that if gravity is the concern, the nucleus can be assumed stationary due to the large relative distances involved.
  • Some participants reference the Born-Oppenheimer approximation, indicating it holds well under the proposed circumstances.
  • A challenge is raised regarding the concept of 'orbits' for electrons or muons, emphasizing that they do not have well-defined distances from the nucleus and that gravitational forces are negligible compared to electromagnetic forces.
  • A participant shares their intention to explore the physics of the model without prior reading of referenced articles, indicating a desire for independent exploration.
  • One participant presents a detailed mathematical formulation of the Schrödinger equation for the system, outlining their approach to treat it as two two-body problems and providing expressions for the wave functions involved.
The discussion contains multiple competing views, particularly regarding the assumptions about particle behavior and the validity of certain approximations. There is no consensus on the implications of the proposed model or the correctness of the assumptions made.
Participants express uncertainty about the implications of mass ratios and the applicability of various approximations, such as the Born-Oppenheimer approximation. The discussion also highlights the complexity of modeling interactions in this system.
jfy4
Hi,
I would like to model an alternate to Muonic helium, and I need some help. I got this idea from a professor of mine who mentioned it off hand in a lecture. The idea is the following:
Model a helium nucleus with one electron, and one muon.
This would have two fermions "orbiting" however, the particles are distinguishable and so none of the indistinguishably ideas around the electrons in the atom would apply.
One of my first question is this: The muon is considerably more massive than the electron, the ratio of mass between the nucleus and the muon is 1 [itex]m_\mu[/itex] is 0.0283466 times smaller than 1 [itex]m_\alpha[/itex]. So the muon is [itex]\approx 3\%[/itex] the mass of a helium nucleus. Is this small enough to still approximate a stationary center?
If you are referring to gravity as moving the nucleus then you may assume so. Seeing as the relative distance from the nucleus to the the first orbit is incredibly large, gravity would not have an effect on the nucleus.
Well, your professor probably mentioned it due to the fact there was an http://www.sciencemag.org/content/331/6016/448" .
The ground-state is a singlet, so as far as that's concerned, the two particles are distinguishable anyway, since they've got opposite spin.
As for your question: Yes, the Born-Oppenheimer approximation was found to hold up well under the circumstances.
Zush: What on Earth are you on about? Electrons (or muons) don't have 'orbits', nor stay at any well-defined distance from the nucleus. And the gravitational attraction is over 50 orders of magnitude smaller than the electromagnetic force between the particles.
Wow, thanks for this article. Do you think anyone will mind If I try and do this without reading the article first, as an exercise. See if I can do physics without seeing it first.
I decided to assume that the nucleus was stationary. The Schrödinger equation is then
[tex]-\frac{\hbar^2}{2m_\mu}\nabla^{2}_{\mu}\Psi(\vec{r}_\mu, \vec{r}_e) -\frac{\hbar^2}{2m_e}\nabla^{2}_{e}\Psi(\vec{r}_\mu, \vec{r}_e)+ke^2\left(-\frac{Z}{r_e}-\frac{Z}{r_\mu}+\frac{1}{r_{e\mu}}\right)\Psi(\vec{r}_\mu, \vec{r}_e)=\hat{E}\Psi(\vec{r}_\mu, \vec{r}_e).[/tex]
I'm going to take
[tex]H'=\frac{ke^2}{r_e\mu}[/itex]<br /> <br /> as the perturbation and then divide the wave function into two parts<br /> <br /> [tex]\Psi(\vec{r}_\mu, \vec{r}_e)=\psi(\vec{r}_\mu)\phi(\vec{r}_e).[/itex]<br /> <br /> and write [itex]\hat{E}=\hat{E}_\mu+\hat{E}_e[/itex].<br /> <br /> I'm then going to treat this as two, two-body problems with the Helium nucleus and the Muon, and the Helium nucleus and the electron. Both of these problems have the normal hydrogenic wave function solution<br /> <br /> [tex]\Phi_{nlm}(r,\theta,\phi)=-\left[\frac{4(n-l-1)!}{(na_0)^3n\left[(n+l)!\right]^3}\right]^{1/2}\rho^l L_{n+l}^{2l+1}(\rho)e^{-\rho/2}Y_{l}^{m}(\theta,\phi)[/tex]<br /> <br /> where [itex]\rho=2r/na_0[/itex] and [itex]a_0=\hbar^2/\bar{\mu} e^2[/itex]. Here [itex]\bar{\mu}[/itex] is the reduced mass of either one of the systems (I'm running out of symbols...). [itex]L_{n+l}^{2l+1}(\rho)[/itex] and [itex]Y_{l}^{m}(\theta,\phi)[/itex] are the Leguerre polynomials and the Spherical Harmonics respectively. For this Hydrogenic solution, [itex]n,l,m,r,\theta,\phi[/itex] are all dependent on the system, and so are not the same in general for both systems. Then the total unperturbed wave function for the system is<br /> <br /> [tex]\Psi_{\{n \}}(\vec{r}_\mu , \vec{r}_e)=\psi_{\{n_\mu \} }(\vec{r}_\mu)\phi_{\{n_e \}}(\vec{r}_e).[/tex]<br /> <br /> Here [itex]\{n\}[/itex] is the set of quantum numbers. Then the ground state of this atom is<br /> <br /> [tex]\Psi_{100,100}(\vec{r}_\mu, \vec{r}_e)=\frac{1}{\pi}\left(a_{0_\mu}a_{0_e}\right)^{-1/2}e^{-(r_\mu/a_{0_\mu}+r_e/a_{0_e})}.[/tex]<br /> <br /> Tomorrow, if everything is fine, I will calculate the first correction to energy and other interesting items. Stay tuned.[/tex][/tex]
  • · Replies 0 ·
  • · Replies 18 ·
11K
10K
