Deriving info from reducible representations
The discussion focuses on deriving information from reducible representations in molecular symmetry, specifically for water (H2O) and sulfur trioxide (SO3). It establishes that water has two non-degenerate stretching modes, one of A1 symmetry and one of B2 symmetry, as stated in "Inorganic Chemistry" by Housecraft. The conversation clarifies that SO3 indeed has three stretching vibrational modes due to its three identical SO bonds, which can be analyzed through the symmetry properties of the molecule's irreducible representations.
  • Understanding of molecular symmetry and point groups, specifically C2v.
  • Familiarity with reducible and irreducible representations in group theory.
  • Basic knowledge of vibrational modes in molecular chemistry.
  • Experience with normal mode analysis and local mode picture concepts.
  • Study the application of group theory in molecular vibrations using "Inorganic Chemistry" by Housecraft.
  • Learn about normal mode analysis techniques for complex molecules like SO3.
  • Explore the concept of degeneracy in vibrational modes and its implications in molecular symmetry.
  • Investigate the relationship between local modes and normal modes in vibrational spectroscopy.
Chemistry students, molecular physicists, and researchers in spectroscopy who are analyzing molecular vibrations and symmetry properties in compounds like water and sulfur trioxide.
ampakine
Heres the reducible representation made by counting the number of bonds left unchanged by each symmetry operation of water:
[PLAIN]http://img808.imageshack.us/img808/704/red0.png
and here's the irreducible representations extracted from it:
http://imageshack.us/m/695/3829/red01l.png
in the book Inorganic Chemistry by Housecraft it states that "This result tells us that there are two non-degenerate stretching modes, one of A1 symmetry and one of B2 symmetry."
I don't understand how that result tells you anything about the number of stretching vibrational modes in the molecule. For a slightly more complex molecule SO3 here's the reducible representation you get from the bonds:
http://imageshack.us/m/821/323/red1t.png
and here's the IRs extracted from it:
http://imageshack.us/m/155/9027/red11.png
so what does this result tell you? Does that mean that SO3 has 3 stretching vibrational modes?
Chemistry news on Phys.org
The symmetry of a molecule is a fundamental property .. by definition, any normal mode vibration of the molecule must belong to one of the irreducible representations of the symmetry group for the molecule. By inspection, you might expect water to have two stretching modes .. one for each OH bond, that is called the local mode picture. The problem with the local mode picture is that those local vibrations involving motion of only one OH bond do not transform as one of the irreducible representations (or irreps) of the C2v point group. Thus we need to create normal modes by generating linear combinations of local modes that satisfy the correct symmetry properties. The method in the book you are reading is actually a shortcut for a more complicated and systematic way of determining the symmetries of the normal modes. It makes use of the fact that the only way a symmetry element can contribute to the character of the *reducible* representation for all possible vibrations of a molecule is if it leaves the positions of one or more atoms unchanged. Depending one how much group theory you have learned, that may not make much sense to you, but the technique does work (whether or not you know group theory ;).
Yes exactly ... can you figure out their symmetries and degeneracies? It makes sense that SO3 should have 3 stretching vibrations, since there are 3 identical SO bonds (by symmetry) whose individual vibrations are the local modes that are combined to form the normal modes .. there are always the same number of local and normal modes for a given type of vibration. Can you figure out how many bending vibrations SO3 has, and what their symmetries are?
