How to Calculate Outlet Pressure and Temperature in a Pipe?
The discussion focuses on calculating outlet pressure and temperature in a pipe with specific parameters: an outer diameter of 25mm, inner diameter of 24mm, length of 84mm, normal inlet pressure of 6 bar, normal inlet temperature of 150°C, maximum inlet pressure of 11.5 bar, maximum inlet temperature of 230°C, and a mass flow rate of 4 kg/min. To determine the outlet conditions, users should calculate the Reynolds number, friction factor, head loss, and pressure drop, assuming a roughness factor of 0.00015 ft for the piping. The analysis must consider turbulent flow and friction unless ideal conditions are explicitly stated.
  • Understanding of fluid dynamics principles
  • Knowledge of Reynolds number calculation
  • Familiarity with friction factor determination in turbulent flow
  • Basic concepts of head loss in piping systems
  • Research how to calculate the Reynolds number for fluid flow
  • Learn about the Darcy-Weisbach equation for head loss
  • Study methods for determining friction factors in turbulent flow
  • Explore the impact of pipe roughness on flow characteristics
Engineers, fluid mechanics students, and professionals involved in piping system design and analysis will benefit from this discussion.
kadiravann
Outer dia=25mm,Inner Dia=24mm,Length=84,Normal innlet pressure=6 bar,Normal inlet temp=150°C,Max innlet pressure=11.5 bar,Max innlet temp=230°C ,Mass flow rate=4 kg/min,
what is the Outlet pressure&Temp?.Which formula I have to Use.Pls Help me
Are you given any equations, the viscosity, or the piping material?
To solve this I would assume a roughness factor for the piping (e=0.00015 ft is good) and calculate the reynolds number, then the fraction factor, then head loss, and then finally a pressure drop.
Unless the problem specifically tells you to assume ideal conditions and zero friction, you have to assume it is turbulent flow and use a the friction factor - otherwise the scenario is bogus!
Please let me know if you have any more info and we will solve this.
  • · Replies 38 ·
