Creating MadGraph 5 model folders
  • Context: Graduate
  • Thread starter Thread starter chrispb
    Model
This discussion focuses on integrating SoftSUSY 3.1.7 outputs into MadGraph 5 for computing cross sections. The user encountered issues with the param_card.dat file, which is no longer recognized by MadGraph 5 as an input. Johan, a MadGraph author, clarified that users can still utilize param_cards in MG5 by generating the desired process, placing the card in the Cards directory, and ensuring they are using version 1.4.x for SLHAI compatibility with the default UFO MSSM model.
  • Familiarity with SoftSUSY 3.1.7 for generating particle spectra
  • Understanding of MadGraph 5 version 1.4.x and its input requirements
  • Knowledge of SLHAI format for model compatibility
  • Basic experience with the MSSM (Minimal Supersymmetric Standard Model)
  • Explore the process of generating cross sections in MadGraph 5
  • Research the SLHAI format and its implications for model compatibility
  • Learn how to structure model folders in MadGraph 5
  • Investigate the differences between MadGraph 4 and MadGraph 5 regarding input files
This discussion is beneficial for particle physicists, researchers using MadGraph for simulations, and anyone working with supersymmetry models in computational physics.
chrispb
I used SoftSUSY 3.1.7 to create a spectrum that I'd now like to input into MadGraph 5 to compute cross sections with. However, the MadGraph calc that I used to use (on their webpage) is outputting me a param_card.dat file, which MG5 no longer appears to use as an input in the model folder. I want to turn this model (which is just MSSM at a specific point in parameter space, RG evolved) into a MG-compatible model folder without inputting each and every number by hand. Does anyone have some advice as to how I could go about doing this, or at least making MG5 play nicely with the param_card.dat file? MG4 requires g77, which seems to not be compatible with the latest version of gcc; otherwise I'd just run that instead. Thanks!
Hi chrispb, I am one of the MadGraph authors. You use param_cards in MG5 just as in MG4: Generate the process you are interested in, put the card in the Cards directory (or if you do it online, just upload the card), and run. Note that you need v. 1.4.x in order to use an SLHAI-compatible card with the default UFO mssm model.
Please note that in order for us to directly receive your questions regarding MadGraph, please post your questions at https://answers.launchpad.net/madgraph5 instead of Physicsforums.
All the best,
Johan
  • · Replies 23 ·
  • · Replies 152 ·
12K
  • · Replies 127 ·
28K
  • · Replies 20 ·
