Effect of parachute on free fall?
The discussion revolves around understanding the effect of a parachute on free fall, particularly focusing on the calculations involving air resistance and drag forces. The original poster is exploring how these factors influence the speed and safety of a free fall, as well as potential applications in other contexts like drag racing.
  • The original poster attempts to understand the air resistance formula and its components, including the drag coefficient. They express uncertainty about the calculations and seek clarification on how to apply the formula to both free fall and drag racing scenarios.
  • Some participants question the complexity of air resistance in relation to the project timeline and suggest that experimental determination of the drag coefficient could be beneficial.
  • Others suggest that solving a differential equation may be necessary to accurately determine the speed of a free-falling object with a parachute.
The discussion is ongoing, with participants providing insights into the air resistance formula and its application. There is a recognition of the challenges posed by the complexity of the topic, but some guidance has been offered regarding experimental methods and the need for numerical solutions.
The original poster is under a time constraint to complete a project for a high school physics class, which may limit their ability to explore the topic in depth. There is also a mention of uncertainty regarding the units of measurement for the calculated forces.
pihotar
I was told i have till wednesday to do a project on physics I've never done before in class, this being a regular high school physics class. So i decided to figure out how a parachute affects free fall and the calculations and stuff to show this.
So far I've found an Air Resistance formula that goes like this:
F-air=0.5pv(squared)AC(sub-d)V
I don't know how to type the squared sign so i wrote it in, and the C(sub-d) refers to the d being sort of like an exponent but below instead of above the letter.
Cd I've learned is called the drag coefficient, but to calculate that I've found several formulas that i cannot understand amongst the internet and i need help understanding the formula.
Also i was thinking of using the formula to determine the air resistance of a free falling man and the velocity and then comparing it to the same calculation with a parachute and seeing the difference in speed to where youd survive the fall. Do you think it would work?
Also also would i be able to find out the decelleration effect of a parachute on a drag racing car in any way?
Thank you for your time, Pihotar
It's a good idea for a project, but air resistance adds quite a bit of complexity so you may be cutting it close on time.
I'm not sure why you have the V in there, but yes, drag is given by:
[tex]F_{drag} = C_D \frac{1}{2}\rho V^2 A[/tex]
Like you've said, [itex]C_D[/itex] is the coefficient of drag.
[itex]\rho[/itex] is the density of air
V is the velocity
A is the cross sectional area facing the air flow.
The drag coefficient is usually determined experimentally. You can probably find values for the drag coefficient for a parachute online. You could also do your own experiment with a small parachute to find the drag force, and then use the drag equation to find [itex]C_D[/itex].
You could do this. The difficulty you'll have here is that you'll need to solve a differential equation to find the speed. You'll probably have to solve it numerically with a spreadsheet or a programming language.
Yes. If you can find the drag coefficient for the parachute and you know the speed of the racer, you can describe the dynamics of the car.
So say i have a velocity of 53 m/s, p = 1.22, Cd= 1.5, nd the area of my parachute is, i don't know 5 meters, th force of air resistance would be 12851.1? I don't know the unit of measure for it and i just want to make sure that my calculatio is right because thatrs a pretty huge number.
That calculation would be correct, yes. If you use MKS units, force is in Newtons, and you would need the air density in kg/m^3. The unit for area is m^2, by the way.
Since the drag force is a function of velocity squared, at high speeds the drag force becomes very large.
  • · Replies 16 ·
