Exploring Complex Waves and their Harmonics
The discussion revolves around the production of complex waves and their harmonics in musical instruments, exploring why different harmonics are generated rather than just the fundamental frequency. The scope includes theoretical aspects of wave behavior in musical contexts and the physical mechanisms involved in sound production.
  • One participant questions why musical instruments produce multiple harmonics instead of solely the fundamental frequency when played.
  • Another participant suggests that the initial excitation of the instrument involves a broad spectrum of frequencies, which contributes to the generation of harmonics.
  • A request for further explanation and elaboration on the topic is made by a participant.
  • It is noted that all musical instruments possess some form of resonant cavity, which plays a crucial role in the production of harmonics and subharmonics.
  • One participant explains that the shape, material, and construction of the resonant cavity influence the harmonics produced by the instrument.
  • A visualization of the plucking process on a guitar is provided, illustrating how both fundamental and higher-order modes are excited, and how selective excitation of modes can occur through techniques like artificial harmonics.
Participants present various viewpoints on the mechanisms behind harmonic production, indicating that multiple competing views remain without a consensus on the specifics of the processes involved.
The discussion does not resolve the underlying assumptions about wave behavior and the specific contributions of resonant cavities to harmonic generation.
Cheman
Complex waves...
I have learned that with a musical instrument you set up standing waves of the fundamental frequency as well as other harmonics which cause the specific "quality" of the sound - my question is why do you produce different harmonics and not just the fundamental frequency? When you pluck a string or blow an air column why do you not just produce one wave? eg - the fundamental frequency?
Thanks. :-)
You drive the instruments with a broad spectrum source (plucking, e.g., is not monochromatic!) so a broad range of frequencies are present at the outset.
Please could people explain and elaborate? :rolleyes:
if you look at any musical instrument out there, you will notice that all of them have some for of resonant cavity. For stringed instruments like violins and guitars and pianos, this is the body of the instrument. For wind instruments, this is the tube form of the instrument.
The standing wave vibrations you produce at the source (reed, string, whistle) are transmitted to the body which resonate at their particular frequencies. this is where many of the subharmonics that produce the tones and depth characteristic of different instruments come from.
The harmonics produced depend on the shape, material and construction of the resonant cavity.
I think one easy way of visualizing it is as follow. Take a guitar for instance, you pluck it by quickly displacing and releasing the string. Now the shape of the displaced string will have certain overlap with the fundamental vibrating mode, so some energy goes into this mode, and the same goes for higher order modes as well. So a large family of modes is excited by plucking.
However, you can also selectively excite a smaller family of modes as well, this is how artificial harmonic works in guitar and violin. For example by gently touching the middle point of a guitar/violin string when you pluck, you essentially introduce a node to that point by restraining it from vibrating. In this case only those vibrating modes with a node at the middle of the string will get excited.
  • · Replies 41 ·
17K
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 101 ·
47K
