Moments of Inertia, almost got it
The problem involves calculating the moment of inertia for a structure made of three identical thin rods, each of length L and mass m, welded perpendicular to one another. The assembly is rotated about an axis that passes through the end of one rod and is parallel to another. Participants are exploring the application of the parallel-axis theorem in this context.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the moment of inertia using known formulas for the rods but expresses uncertainty about the need for the parallel-axis theorem. Some participants question the configuration of the rods and whether the theorem is applicable based on their arrangement.
The discussion is ongoing, with participants clarifying the configuration of the rods and exploring the implications of their arrangement on the moment of inertia calculation. There is no explicit consensus yet, but the dialogue is productive in examining the assumptions and interpretations of the problem.
Participants note that the rods are joined at their midpoints, and there is a discussion about the relevance of the parallel-axis theorem given the specific setup of the assembly resembling an xyz coordinate system.
sisigsarap
The problem is:
Three identical thin rods, each of length L and mass m, are welded perpendicular to one another. The assembly is rotated about an axis that passes through the end of one rod and is parallel to another. Determine the moment of intertia of this structure.
Ok what I know is that the rod which is connected to the axis of rotation has inertia of I = 1/3ML^2
And I know that the rod which is parallel to the axis has inertia of I = ML^2
So far I have (1/3ML^2) + (ML^2) and I just need one other moment of intertia which I am having difficulty finding.
I believe I need to apply the parallel-axis theorem, but I don't understand why.
If someone could please explain why you would use this theorem it would be very helpful! Thanks!
Can you elaborate? There are MANY ways to join three rods at right angles to each other. Are they joined at their midpoints, ends, something in between or other permutations?
The three rods are joined at their midpoints.
sisigsarap said:
The problem is:
Thanks!
do you mean the assembly looks some what like an xyz coordinate system with all of the centers of mass(midpoints) at the origin and rotating about one of the axes? If that's the case I don't think that the parallel axis theorem applies.
Yes the assembly looks some what like an xyz coordinate system with all of the centers of mass (midpoints) at the center.
  • · Replies 28 ·
  • · Replies 21 ·
