New Reply
Changing string length -> changing fundamental freq.
Share Thread Thread Tools
May18-11, 01:25 PM   #1
Don't have the solution, just want to check if I did this properly.
A 0.5 m violin string fixed at both ends has its first harmonic or fundamental frequency at 440 Hz. Assuming the string is non dispersive, calculate the length it should have so its new fundamental frequency will be 528 Hz.
2. Relevant equations
The nth harmonic's wavelength is 2L/n, where L is the length of the string.
[tex]\lambda[/tex][tex]\upsilon[/tex] = v
3. The attempt at a solution
Apparently the phase velocity of the given fundamental harmonic is 440m/s.
If I want a new [tex]\upsilon[/tex] of 528 Hz, I'd need a string of length = v/2[tex]\upsilon[/tex], so 440/2(528) = 0.416m. A shorter string = higher frequency which makes sense, but my question is: how is the velocity of the wave still 440 m/s? I just shortened the string, wouldn't the tension be greater necessarily(or the linear density decreased as a consequence), hence the velocity would change?
For the sake of simplicity: does the new fundamental harmonic at 528Hz still propagate at 440m/s along the string?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
May19-11, 02:35 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by Lavabug View Post
You can choose the tension in the shorter string the same as in the longer one. (It is not stretched to the original length). So the linear density stays the same.
ehild
New Reply
Thread Tools
Similar Threads for: Changing string length -> changing fundamental freq.
Thread Forum Replies
Falling string: Momentum and force changing over time Introductory Physics Homework 0
Changing force, linearly changing. Introductory Physics Homework 16
Falling string: Force and momentum changing over time Introductory Physics Homework 0
pendulum with changing length Introductory Physics Homework 0
[SOLVED] Help: Length Contraction and changing Frames Advanced Physics Homework 2
