Solving Complex Equations Involving a,b,c,p,q,r
  • Thread starter Thread starter juantheron
    Complex
The discussion focuses on solving complex equations involving variables a, b, c, p, q, and r. The key equations are \(\frac{p}{a}+\frac{q}{b}+\frac{r}{c} = 1+i\) and \(\frac{a}{p}+\frac{b}{q}+\frac{c}{r} = 0\), with the goal of finding the value of \(\frac{p^2}{a^2}+\frac{q^2}{b^2}+\frac{r^2}{c^2}\). A correction was made to the second equation, leading to a solution of 2i for the desired expression. The method involved squaring the first equation and substituting the corrected second equation to simplify the problem.
  • Understanding of complex numbers
  • Familiarity with algebraic manipulation of equations
  • Knowledge of squaring equations
  • Ability to substitute variables in equations
  • Study complex number operations and properties
  • Learn about algebraic manipulation techniques
  • Explore methods for solving systems of equations
  • Investigate the implications of squaring both sides of an equation
Students studying complex analysis, mathematicians solving algebraic equations, and anyone interested in advanced algebraic techniques.
juantheron
If [tex]\mathbf{a,b,c,p,q,r}[/tex] are complex number
and [tex]\displaystyle\mathbf{\frac{p}{a}+\frac{q}{b}+\frac{r}{c} = 1+i}[/tex]
and [tex]\displaystyle\mathbf{\frac{a}{b}+\frac{b}{q}+\frac{c}{r} = 0}[/tex].Then find value of
[tex]\displaystyle\mathbf{\frac{p^2}{a^2}+\frac{q^2}{b^2}+\frac{r^2}{c^2}=}[/tex]
No idea
I think you have a mistake in the equation above. I believe it should be
[tex]\frac{a}{p}+\frac{b}{q}+\frac{c}{r} = 0[/tex]
I made that change and was able to get a value of 2i for the expression you want to evaluate. What I did was to square both sides of the equation whose right side is 1 + i. If you work with the other equation, as corrected above, you can substitute it in the other equation to arrive at a simplified result.
juantheron said:
Then find value of
No idea
Thanks Mark44.
  • · Replies 20 ·
  • · Replies 29 ·
