| New Reply |
Venturi tube help needed in determining pressure difference |
Share Thread | Thread Tools |
| May20-11, 01:16 AM | #1 |
Water flows through venturi tube at 0.3 litres/s. Diameter of venturi tube is 32mm to 20mm to 32mm and the water density is 1000kg/m^3. 2. Relevant equations a) Assuming head loss is neglible, what is pressure difference between 1 and 2. b) If pressure head difference between these is 45mm what is head loss. 3. The attempt at a solution So far I have V2 = P1A1V1/P2A2 = 0.9548 and V1 (Q/A) = 0.3731 delta H 1/2 = H1 - H2 = 1/2g (V2^2-V1^2)) delta H 1/2 = 39.3mm Where do I go from here, if this is even correct ? Thanks a lot for your help. |
| May20-11, 05:52 AM | #2 |
hi timothy1875! welcome to pf!
![]() (try using the X2 and X2 icons just above the Reply box )i don't follow you …use the fact that the volume per time is constant, and Bernoulli's equation
| May20-11, 06:49 AM | #3 |
Hi Tim,
Thanks for getting back to me.I am trying to answer the question but think I may be going about it the wrong way. Using the Bernoulli equation do I need to transpose to find P ? |
| May20-11, 06:51 AM | #4 |
show us what you have so far
| May20-11, 07:06 AM | #5 |
delta H 1/2 = H1 - H2 = 1/2g (V22-V12) delta H 1/2 = 39.3mm This where I have got to so far, :( |
| May20-11, 07:15 AM | #6 |
![]() where does it come from? |
| May20-11, 07:25 AM | #7 |
Basically we have been set this question and there are numerous equations on the back that we have to pick from. I take it from your response I have selected the wrong equation initially. Should it be 1/2g (V22 - V1 2) ??
| New Reply |
| Thread Tools | |
Similar Threads for: Venturi tube help needed in determining pressure difference
| Why pressure is lower at the small bore of a venturi | General Engineering | 1 | ||
| Confused about venturi tube | Classical Physics | 17 | ||
| Venturi Meter:: Finding Pressure Difference | Introductory Physics Homework | 5 | ||
| Conceptual Pressure Question: Fluid Pressure in a U-Tube | Introductory Physics Homework | 1 | ||
| Venturi tube calculation | Introductory Physics Homework | 0 | ||
