Calculate the power of a the lift motor
  • Thread starter Thread starter taomay
    Lift Motor Power
The discussion revolves around calculating the power required for a lift motor to raise a load of bricks on a construction site. The scenario involves lifting 400 kg of bricks a distance of 50 meters in 24 seconds, with participants exploring different aspects of the calculation and requirements for accurate power assessment.
  • One participant requests assistance in calculating the power of the lift motor based on the given parameters.
  • Another participant challenges the first request by suggesting that the requester should determine the answer themselves.
  • A third participant provides a detailed calculation, converting mass to weight and calculating work done and power output, arriving at a power requirement of 8.175 kW.
  • A later reply introduces additional considerations for calculating the horsepower required for a cable-driven lift, noting the need for more data such as desired speed, counterweight percentage, and efficiency factors, indicating that the initial calculation may not account for all necessary variables.
Participants do not reach a consensus, as there are differing views on the adequacy of the initial calculation and the additional factors that must be considered for a complete assessment of the lift motor's power requirements.
The discussion highlights limitations in the initial calculation, including assumptions about lift type and missing parameters that could affect the power requirements.
Individuals interested in mechanical engineering, lift design, or those studying physics related to work and power calculations may find this discussion relevant.
taomay
Please help :
Calculate the power of a the lift motor,when is lift on a distance on a building site lift 400kg of brick50m to the top of a buiding in 24 seconds
Ans ?
Regards.
taomay
You tell us.
taomay said:
Please help :
Calculate the power of a the lift motor,when is lift on a distance on a building site lift 400kg of brick 50m to the top of a buiding in 24 seconds
Ans ?
Regards.
taomay
Ans :
mass= 400kg (convert mass to weight 1kg=9.81N (force of gravity on 1kg)
400x9.81=3924N
Workdone (j)= force xdistance
3924x50 =196200
Power = 196200 /24= 8175 W
convert to KW =8.175KW
Assuming that this is a cable driven lift and not a hydraulic lift, more data is required to calculate the HP required to lift the load:
Desired speed of lift
% of counterweighting
Hoisting machine eff.
acceleration rate and rate of change of acceleration rate (known as jerk rate)
Hoistway eff.
H.P. required = Speed (fpm) x capacity (lbs) x Percentage of uncounterweighted load (usually .4 to .5 / 33000) / overall eff.*
* this can actually range anywhere from 40% to 90% depending upon machine be geared or gearless, the roping type usually being 1:1 or 2:1 as well as the types of guide shoes (roller or slide).
If steep accelleration and jerk rates are required to meet a specific performance than a larger motor maybe required to meet those peak torque requirements.
To convert HP to KW, multiply the HP times .746
  • · Replies 31 ·
