How Do You Solve the QHO with a Sinusoidal Perturbing Potential?
The discussion revolves around solving the quantum harmonic oscillator (QHO) with a sinusoidal perturbing potential of the form VoSIN(BX). Participants are exploring how to find the ground state energy and the ground state eigenket |g> in this context.
  • Mixed
  • The original poster attempts to use a Taylor expansion of the potential and rewrite the X operator in terms of creation and annihilation operators but finds this approach unproductive. They also consider rewriting the potential using exponential forms but express concern about the compatibility of these forms with the QHO eigenkets.
  • Some participants suggest using perturbation theory, questioning whether the ground state should be found to first or second order in the perturbation.
  • Others note that the first order perturbation can be computed directly as an integral over the perturbing potential using the ground state wavefunctions without the need for a Taylor series.
The discussion is ongoing, with participants providing guidance on the application of perturbation theory and clarifying the steps needed to compute the first order correction. There is an acknowledgment of the original poster's confusion regarding the approach, and some participants express optimism about the simplicity of the first order calculation.
There is a mention of the instructor's advice against using the Taylor expansion method, indicating a potential constraint on the approaches being considered. The original poster also expresses uncertainty about the outcome of the integral, suggesting a need for further exploration of the second order corrections.
taloc
I am tasked with solving the QHO with a sinusoidal perturbing potential of the form VoSIN(BX). I need to find the ground state energy as well as the ground state eigenket |g>.
[tex]H_{o} = \frac{P^{2}}{2m} + \frac{1}{2}m \varpi^{2}[/tex]
[tex]H = H_{o} + Asin(BX)[/tex]
[tex]E^{(o)}_{n}=\hbar\varpi(n+\frac{1}{2})[/tex] Which is the unperturbed energy
My first stab at this problem involved performing a Taylor expansion of the potential and the rewriting of the X operator in terms of the creation and annihilation operators:
[tex]X = \sqrt{\frac{\hbar}{2m\varpi}}(a^{\dagger}+a)[/tex]
This process was not very rewarding. I found myself with no method for determining when to terminate the expansion.
An alternative approach would be to rewrite the potential as:
[tex]Asin(BX) = \frac{A}{2i}(e^{iBX}-e^{-iBX})[/tex]
My concern with this method is that the |n> kets used in the QHO are not eigenkets of X and therefore do not play nicely with the exponentials. Do I need to perform a change of basis? Essentially creating a new set of kets composed of a linear combination of the |n> kets? Any advice would be greatly appreciated!
Cheers!
Have you thought about using perturbation theory? I am guessing [itex]V_0[/itex] is small since you mention it is a perturbative potential. So are you supposed to find the ground state to first order in [itex]V_0[/itex]? Or 2nd order?
nickjer,
Thank you for the reply. I do need to apply pertubation theory to solve this problem. The problem I am facing involves having the X operator of the perturbing potential "locked up" inside a trigometric function. If I were to expand the trig function in a Taylor Series I could then perform the analysis for first order corrections (which vanish) and then proceed to second order corrections. I asked my instructor about the Taylor expansion method and was told this was not the appropriate path to take. He confirmed that I must rewrite the Sin function in terms of the exponentials I gave in the initial post. I am completely lost as to how I should proceed from this point on.
Cheers,
First order perturbation is just an integral over the perturbing potential:
[tex]E_n^{(1)}=\langle n^{(0)}|V|n^{(0)} \rangle[/tex]
So just integrate over that potential with the ground state wavefunctions for a simple harmonic oscillator. No need for Taylor series.
Wow! Is that all i need to do? That is far easier than i expected. i will attempt to generate the ground state energy tomorrow morning. I was attempting to evaluate the expression in a much more general case. I suspect that the integral will be zero and require a second order approximation, but here is to hoping.
Thank you very much for your help nickjer, i will get back to you in the morning with my results.
Ceers!
