How Does Electrostatic Force Affect Charges Within a Uniformly Charged Sphere?
The discussion focuses on calculating the electrostatic force exerted on charges within a uniformly charged sphere. The total force on the northern hemisphere is derived using Coulomb's Law and Maxwell's stress tensor, resulting in the formula F = (2/5) * (9 * 10^9) * (Q^2 / (4/3 * pi * R^3)) * pi^2 * R^5. Evaluating this for a sphere of radius R=1m containing 10kg of electrons reveals significant repulsive forces between two such spheres separated by 3000km. The analysis also compares the electrostatic force to gravitational force, demonstrating that the electrostatic repulsion vastly exceeds gravitational attraction.
  • Coulomb's Law
  • Maxwell's stress tensor
  • Spherical coordinates integration
  • Basic electrostatics concepts
  • Study the derivation of Coulomb's Law in detail
  • Learn about Maxwell's stress tensor applications in electrostatics
  • Explore the implications of electrostatic forces in particle physics
  • Investigate gravitational vs. electrostatic force comparisons in various contexts
Physicists, electrical engineers, and students studying electrostatics and force interactions in charged systems.
maxx
Consider a solid sphere of radius R containing a total charge Q which is uniformly distributed throughout the volume with a volume charge density rho.
a) find the total force exerted by the electrostatic field on the charge in the 'northern hemisphere'. express your answer in terms of the total charge Q and the radius R of the sphere
b) evaluate your answer to part a) using R=1m containing 10kg of electrons
c) find the repulsive force between two sperical volumes of radius R=1m, each containing 10kg of electrons held fixed and separated by a distance of 3000km
d) by what factor does the magnitude of the repulsive electro. force, found in part c) exceed the gravitational attractive force of the two masses
e) if the forces holding the two spherical volumes of electrons, fixed at a distance of 3000km, were to vanish, find the initial acceleration that would be experienced by the two 10kg masses. express your answer of units of g-forces of 9.81m per second squared.
The most straightforward way to sove your problems is to use Maxwell's stress tensor
to find the appropriate forces. I'm sure I've seen the first problem done in textbooks, but the specifics escape me.
Regards,
Reilly Atkinson
a) To find the total force exerted by the electrostatic field on the charge in the northern hemisphere, we can break it down into smaller infinitesimal charges and integrate over the volume. The force exerted by an infinitesimal charge dq located at a distance r from the center of the sphere is given by Coulomb's Law: dF = k * (Q * dq) / r^2, where k is the Coulomb's constant. Since the charge is uniformly distributed, we can express dq in terms of the volume charge density rho as dq = rho * dV, where dV is the volume element. The volume element in spherical coordinates is given by dV = r^2 * sin(theta) * dr * dtheta * dphi. Integrating over the northern hemisphere (theta from 0 to pi/2 and phi from 0 to 2*pi), we get:
F = ∫∫∫ dF = ∫∫∫ k * (Q * rho * r^2 * sin(theta) * dr * dtheta * dphi) / r^2
= k * Q * rho * ∫∫∫ r * sin(theta) * dr * dtheta * dphi
= k * Q * rho * ∫∫ r^2 * sin(theta) * dtheta * dphi
= k * Q * rho * ∫ 0 to 2*pi ∫ 0 to pi/2 ∫ 0 to R r^2 * sin(theta) * r^2 * sin(theta) * dr * dtheta * dphi
= k * Q * rho * (2*pi) * ∫ 0 to pi/2 (sin(theta))^2 * ∫ 0 to R r^4 * dr
= k * Q * rho * (2*pi) * (pi/2) * (R^5 / 5)
= (2/5) * k * Q * rho * pi^2 * R^5
Substituting k = 9 * 10^9 N*m^2/C^2, Q = total charge, and rho = Q / (4/3 * pi * R^3), we get:
F = (2/5) * (9 * 10^9) * (Q / (4/3 * pi * R^3)) * Q * pi^2 *
9K
  • · Replies 26 ·
  • · Replies 36 ·
