| New Reply |
Moments and Bending Moments |
Share Thread |
| May20-11, 05:10 PM | #1 |
| May20-11, 05:51 PM | #2 |
There are several difficulties with your approach.
Why are you not following convention and working from left to right? If you do not do this you need a negative sign in you equations since the positive x increasing direction is left to right. Secondly the integration only works like this with distributed loads, not with point loads. |
| May22-11, 04:54 PM | #3 |
I think I see the problem with my expressions though. Once I take a cut like I have done in the picture, I should still be able to use the force X distance method to work out the moment due to the load and the reaction. But however, since I took my cut this way I need to look at the fact that the loading is described by q as a function of x which begins from the reaction at the left hand side. So, the expression for moment using the Force X distance becomes a little more complicated since the distance is the distance from the point where I have taken the cut, and the loading is being described through the variable x which is measuring the distance from the left reaction. So I need to find an expression that associates the distance x with the distance from the cut, which is going to be a little difficult. Thanks for the reply. |
| May22-11, 05:06 PM | #4 |
Whatever direction conventions you choose you will have to cope with the fact that for many loading conditions the relevant equations, expressed as functions of x, are different on different parts of the beam.
An elegant solution to this is Macaulay's method A google search will reveal many hits eg http://www.colincaprani.com/files/no...hod%201011.pdf There are also some worked examples in recent threads in Physics Forums on this - try a search. go well |
| New Reply |
Similar discussions for: Moments and Bending Moments
| Bending moments Help!!! | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Bending Moments | Classical Physics | 8 | ||
| bending moments | Engineering, Comp Sci, & Technology Homework | 4 | ||
| bending moments | Materials & Chemical Engineering | 4 | ||
| Bending Moments | Engineering, Comp Sci, & Technology Homework | 1 | ||
