Equivalence Principle: Are there any restrictions
The discussion revolves around the Equivalence Principle in the context of gravitational fields and accelerated frames. Participants explore whether the principle implies restrictions on the nature of acceleration, particularly concerning constant versus varying acceleration, and the implications of these distinctions in both Newtonian and General Relativity frameworks.
  • Some participants question whether the Equivalence Principle assumes a constant vectorial acceleration, particularly in cases where acceleration changes direction, such as centripetal acceleration.
  • One participant argues that for an observer in a rotating frame, the direction of the gravitational field does not change over time, suggesting that the distinction between constant and varying acceleration is not significant in General Relativity (GR).
  • Another participant asserts that the Equivalence Principle is valid regardless of whether acceleration is constant or not, emphasizing that it is not possible to determine if a particular acceleration is constant.
  • Some participants discuss the limitations of mimicking gravitational fields with accelerated frames, noting that not every gravitational field can be replicated by an accelerated frame except locally.
  • There is a debate regarding the ability of different mass distributions to reproduce fictitious forces, with some participants expressing skepticism about the equivalence of forces in Newtonian contexts.
  • One participant highlights that the fictitious force along a rotating disk is proportional to the distance from the center, while a ring of matter fails to replicate this force accurately.
Participants express differing views on the implications of the Equivalence Principle regarding constant versus varying acceleration. There is no consensus on whether the principle necessitates constant acceleration or if it can accommodate varying acceleration. Additionally, there are competing perspectives on the ability of different mass distributions to replicate gravitational effects.
Participants note that the discussion involves complex interpretations of gravitational fields and accelerated frames, with references to local versus global frames in GR and the limitations of Newtonian gravity. The conversation also touches on the mathematical intricacies involved in modeling forces in different contexts.
Jorl17
Hello all.
I've been thinking a lot about the Equivalence Principle as it has been taught to me: "The effects of the acceleration (vector) a of a referential are indistinguishable of those of a gravitational field (vector) g=-a". The same book has the phrase: "There is no experience that allows us to distinguish if we are in a gravitational field or attached to an accelerated referential".
Now, here's a simple question: Are there any restrictions? Specifically, as I cannot understand from the sentence, are we assuming a constant (vector) a?
Why am I asking that? I'm not pondering if the module of (vector) a is varying, I'm rather thinking about cases where (vector) a changes in direction -- for example, centripetal acceleration in a uniform rotation.
Can I say that even if (vector) a varies over time (absolute time), the full effects can be described by
[tex]\vec{g}=-\vec{a}[/tex]?
And if your answer is yes, then there is a more specific question: Does this imply that (vector) g varies as well, so that (vector) g isn't equal to (vector) a0 but a changing acceleration over time?
I hope my question is clear, thanks,
Jorl17
To an observer rotating on a carousel in flat spacetime, the direction of the gravitational field is not changing over time.
One way of looking at it is that the equivalence principle is basically a statement that [itex]\vec{g}[/itex] is not the right thing to study. The distinction between time-varying and constant [itex]\vec{g}[/itex] is uninteresting in GR for the same reason that [itex]\vec{g}[/itex] itself is uninteresting in GR. [itex]\vec{g}[/itex] is not a tensor, and you can make it have any value you like by choosing coordinates. Similarly, [itex]d\vec{g}/dt[/itex] is not a tensor, and you can make it have any value you like by choosing coordinates.
Another way of looking at it is that the e.p. basically says that different test bodies follow the same geodesic when given the same initial position and velocity. From this point of view, it should be clear that the e.p.'s validity isn't dependent on any distinction between constant acceleration and non-constant acceleration. If two bodies "fly in formation," i.e., their world-lines are essentially the same, then that's true regardless of your coordinate system (accelerating at a constant rate, at a changing rate, etc.).
Thanks, but I don't think that answered my original question (or I simply didn't get it). Does the Equivalence Principle imply a constant vectorial acceleration (direction included ofc)?
No, it doesn't. It's valid regardless of whether the acceleration is constant. It isn't even possible to decide whether a particular acceleration is constant. (BTW, I edited my post after posting it but before you replied.)
In Newtonian gravity, it does seem that every acceleration could be mimicked by a gravitational field.
However, not every gravitational field can be mimicked by an accelerated frame, except locally. So it requires not so much constant acceleration, but a "constant" gravitational field (I don't know the technical statement for "constant" gravitational field off the top of my head, but it should have something to do with spatial derivatives or tidal forces).
What about, e.g. a cylinder spinning on its access. You are inside. Walk all around the outer wall, and force out from center is uniform. Now further imagine the cylinder is very flat (small dimension in direction of its spin access). Now it is known that spherical shell produces no net gravitation on the inside. I think a thin slice of this would preserve the effect. Then it seems no arrangement of mass could produce the pseudo-gravity of a spinning flat disc.
Obviously 'locally' you could mimic this; locally it is just uniform acceleration. Thus, I think the 'locally' restriction is required for gravity mimicking acceleration as well as for acceleration mimicking gravity.
Well, in GR frames don't even exist globally -- they only exist locally.
I don't think it's true for a ring, but anyway I don't see why you need a physical structure here. All you have to do is transform Minkowski space, represented in the usual coordinates, into a rotating frame.
Zero mass everywhere produces this gravitational field.
I was talking about Newtonian gravity (and Newtonian tidal forces).
I think we're talking in different terms. I interpreted atty as saying that fictitious forces from non-inertial motion could be mimicked by gravity in a Newtonian context. I don't believe this. I don't believe an outward radial force around a ring can be reproduced by any mass distribution.
As for the claim about hollow shell theorem, I didn't work it out. I relied on an intuition that what works for 2 sphere in 3-space inverse square law should work for a 1-sphere in 2-space inverse square law.
Well, now I did calculate things, and immediately see that ring and hollow sphere are completely different,as Bcrowell stated. A ring would have zero internal force for inverse r force law; a sphere for and inverse square force law. However, my calculation still validates my main point. The fictitious force along rotating disk is simply proportional to r (distance from center of disk; for a given angular velocity). Any attempt to emulate this with a ring of matter fails, because the force will be a much more complicated function of radial distance from the center of the ring. In fact, after writing down my integrals for this case (and seeing they would be a bear to integrate exactly) I went looking online. I found the page below, with amusing coincidence that my integrals matched those on this page even down to choice of every symbol, except that I was only interested in the plane of the ring, not altitude above it. This page shows nice graphs of the non-linear r dependence for a ring of matter, validating that it cannot reproduce the fictitious forces of a spinning disk.
http://www.mathpages.com/home/kmath402/kmath402.htm
  • · Replies 44 ·
  • · Replies 24 ·
