Guitar String's 2nd Overtone Frequency
  • Thread starter Thread starter teggenspiller
    Frequency Guitar
The discussion revolves around determining the frequency of the second overtone of a guitar string with a fundamental frequency of 500 Hz. The problem is situated within the context of wave physics and harmonics.
  • Participants explore the relationship between fundamental frequency and overtones, with some attempting calculations based on harmonic definitions. Questions arise regarding the nature of overtones and the process of transitioning between harmonics.
Some participants express confusion about the concept of overtones and harmonics, seeking clarification on how these concepts apply to the problem. There are attempts to explain the relationship between the fundamental frequency and its harmonics, with various interpretations being explored.
Participants note a potential variation in terminology regarding overtones and harmonics, which may contribute to the confusion. The discussion also highlights the need for a deeper understanding of the physical principles behind string vibrations.
teggenspiller
If a guitar string has a fundamental frequency of 500 Hz, what is the frequency of its second overtone?
A. 250 Hz
B. 750 Hz
C. 1 000 Hz
D. 1 500 Hz
fundamental frequency is 2times wavelenth, lambda
and the second overtone=the third harmonic.
well, 3*fundamental frequency would make it 1500. its wrong.
then i was thinking the freqency of fundamental is 2*length of string, so i did 500Hz/2 = wavelength of string and multiplied by 3.
ahh. Futhermore, but foremost, i need to understand what in the heck an overtone is. and why there are 1st, second, 3rd. if i have a string and I am on its first harmonic, how do i get to it's second? by plucking it again? or with time it increases? i don't understand that conceptual part of harmonics and so its preventing me from applying the concepts. but i also need help with that question. thanks!
A. 250 Hz
B. 750 Hz
C. 1 000 Hz
D. 1 500 Hz
I think the answer is 1500 Hz. The only think I can think of is that there is a variation in terminology and the test maker is counting differently.
About overtones: when you pluck a string, you get a standing wave making the string vibrate with a note at the bridge and at the nut (i.e., the two ends of the string). You also get the string vibrating with a nodes at the bridge, nut and center (over a guitar's 12th fret). That is the first overtone (a.k.a. the second harmonic). Having half the wavelength of the the fundamental, it has twice the frequency (i.e., the octave above the fundamental). You can easily demonstrate the existence of the first overtone by plucking the string and then lightly touching it at the 12th fret. That prevent there being an antinode there, preventing the fundamental from sounding. When you do this, it allows the first overtone to keeps sounding (along with other odd-numbered overtones), so you hear the sound leap up an octave.
Plucking the strong also give the other overtones as well. Here is an http://zonalandeducation.com/mstm/physics/waves/standingWaves/standingWaves1/StandingWaves1.html" of multiple standing waves on a violin string. It let's you look at individual harmonics or the sum effect.
thank you so much. i do not completely understand harmonics still, but you provided an EXCELLENT explanation. Thanks!
Let me try again, because it is not that difficult an idea. Have a look at this http://en.wikipedia.org/wiki/File:Harmonic_partials_on_strings.svg" .
When a string vibrates like it is shown in the top of the image, we say it is one half-wavelength. Let's say the string length is L. The wavelength is then 2L. Now suppose the wave moves along the string at speed V. That means the frequency f is given by
f=V/(2L)​
That is the fundamental (or the first harmonic).
While the string vibrates in one half-wavelength, it can also simultaneously vibrate in two half-wavelengths. (The second line of the diagram shows the two half-wavelengths, but not superimposed on the one half-wavelength.) That vibration of the string has a wavelength L and a frequency
f'=V/L = 2f​
and it is call the first overtone (or second harmonic).
Carrying on to the next step, we get
f''=V/(2L/3)= 1.5V/L=3f
Next next comes f'''=4f, f''''=5f, etc.
All those sounds blends together with various volumes to make the string's sound. When two strings sound different (like a guitar string and a banjo string) it is because different overtones are accentuated or supressed.
It that any better?
