Current in Capacitor Discharge Circuit - 5 μC per s
The current in a capacitor discharge circuit is defined as the flow of positive charge. In this discussion, the rate of charge discharge is given as 5 microcoulombs per second (dq/dt = 5 μC/s). The confusion arises from the assumption that the current should be double this rate; however, the correct current is simply 5 μC/s, representing the flow of positive charges. The negative charge flow (electrons) is not counted in the current definition, which only considers the movement of positive charges.
  • Understanding of capacitor discharge principles
  • Knowledge of electric current and charge flow
  • Familiarity with microcoulombs as a unit of charge
  • Basic concepts of electron flow and positive charge carriers
  • Study the relationship between charge, current, and time in capacitor circuits
  • Learn about the role of positive and negative charges in electric circuits
  • Explore the concept of current density and its applications in circuit analysis
  • Investigate the behavior of capacitors in AC circuits and their discharge characteristics
Students studying electrical engineering, physics enthusiasts, and anyone seeking to understand the principles of capacitor discharge and current flow in circuits.
sachin123
A fully charged capacitor is connected in a closed circuit with nothing else in the circuit.
So the capacitor starts discharging.At a certain instant of time the charge on the capacitor is
reducing at the rate of 5 micro coulomb per second(dq/dt =5 μC per s).
What is the current in the circuit at this instant of time?2. The attempt at a solution
My answer is that the current is twice dq/dt which is equal to 10 μC per s because ...
when the capacitor is getting discharged at some rate,that means that the charge on each plate of the capacitor reduces at that rate.But a capacitor has opposite charges on its plates.SO,the current due to +ve charges and -ve charges (in opposite directions)add up ,thus doubling the value.
However the value mentioned as answer is only 5 μC per s.
Can someone tell me why?
Thank You
Current's defined as the number of positive charges that passes at a certain time. At that certain time, a charge equal to 5 μC passes through the capacitor. That's the positive current. Of course there's always a negative current as well, in this case it's the flow of the electrons. The positive current is the flow of the "holes" the electrons leave. So in one direction there are electrons, in the other positive "holes". They both have the same but opposite charge, so the currents are equal but are in different directions. Thus by convention, current's defined for the flow of the positive charges. So in this case, what they're asking for is the current in one of the directions, specifically the positive one.
Oh yes.
Dumb of me.
It is the electrons that flow through the circuit and reach the positive plate and neutralize the positive charge on the plate.
Thanks !
  • · Replies 30 ·
