Vector C & (A x B): True or False?
  • Thread starter Thread starter Chen
    Vector
The discussion revolves around the properties of vector operations involving three vectors: a, b, and c, where vector c is stated to be perpendicular to both a and b. Participants are evaluating various vector expressions to determine their validity.
  • Exploratory, Assumption checking
  • Participants are analyzing different vector expressions involving cross products and dot products, questioning the nature of the results (vector vs scalar) and the implications of vector c's perpendicularity.
The discussion is ongoing, with participants providing insights into the characteristics of the expressions. Some have noted the distinction between scalar and vector results, while others have pointed out the ambiguity in determining which expressions can be considered "true" without further context.
There is a mention of access issues to external resources, which may limit the ability of some participants to engage fully with the content. Additionally, the original poster expresses urgency due to a limited number of attempts for submitting an answer.
Chen
It's given that vector c is perpendicular to both vectors a and b. Which of the following is true:
1) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_01.gif
(a x b) x c
2) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_02.gif
(a x c) dot b
3) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_03.gif
(a x c) x b
4) http://phstudy.technion.ac.il/~wn114071/physweb/question/1_4_04.gif
(a x b) dot c
Can someone please just confirm the answer is (1) because I have only one attempt left at submitting an answer for this question.
Thanks :smile:
I can't open the files. You need authorization for that...
I knew that might happen, so I wrote the expression in each link below. (1) is (a x b) x c, i.e (a cross b) cross c.
Thanks.
It's impossible to say which one is true, because those are all expressions, not equations.
Answers 2 and 4 give you a scalar number. The absolute value is the same for both, but the sign changes.
Answer 1 gives you a null vector (all components equal to 0) since the cross product of A and B is either in the same direction as C or the exact opposite direction of C.
Answer 3 gives you a vector.
  • · Replies 25 ·
