Can u change time on a watch by
  • Context: Graduate
  • Thread starter Thread starter Slickchange1313
    Change Time watch
The discussion revolves around the effects of gravitational forces on the timekeeping of a watch, particularly in scenarios where the net gravitational force is zero. Participants explore the implications of suspending a watch using magnets or other means and how this might affect its timekeeping compared to a standard Earth environment.
  • One participant questions whether placing a watch between two magnets and applying equal gravitational force would alter its timekeeping, suggesting that a net gravity of zero could lead to a different rate of time measurement.
  • Another participant asserts that if the net gravity on a watch is zero, it would record time slightly faster than in a normal environment, but challenges the feasibility of achieving this with magnets.
  • A participant asks for clarification on how much faster the watch would run under these conditions.
  • It is noted that magnets do not affect gravity and that the watch would still fall if released, indicating that the method proposed does not alter gravitational effects.
  • One participant introduces a hypothetical scenario involving hyperdense materials creating a point of zero gravity, discussing how time dilation relates to gravitational potential energy rather than gravitational field strength.
  • Another participant emphasizes that suspending a watch, regardless of the method, does not change its timekeeping rate, as only gravity influences gravitational time dilation.
  • Some participants express confusion over the original question and the technical details involved, while others appreciate the explanations provided.
Participants generally disagree on the feasibility and implications of using magnets to alter the timekeeping of a watch. While some propose that a net gravity of zero could affect time measurement, others argue that only gravity influences time dilation, leaving the discussion unresolved.
Participants reference gravitational time dilation and the relationship between gravitational potential energy and timekeeping, but the discussion includes various assumptions and hypothetical scenarios that remain unverified.
Slickchange1313
this is just a question, but according to physics, if you put a magent on each side of watch (the watch is like half an inch, normal wrist watch) and applied equal gravitational force on the watch in the middle, since the net gravity is zero, would the watch speed up/ slow down in time telling, as in an airplane the speed of a watch is different than on earth, so what would happen if the watch's net gravity was zero?
If the net gravity on a watch these zero, the watch will record time slightly faster than it does in an "Earth-normal" environment. However, this cannot be accomplished with magnets. Magnets can suspend a watch and keep it from falling, but setting the watch on a tabletop will do the same thing. Neither of these have any influence over the effect of gravity on the watch (nor will anything else, as far as we know).
"If the net gravity on a watch these zero, the watch will record time slightly faster than it does in an "Earth-normal" environment"
how much faster?
You're not affecting gravity when you stick a magnet onto a watch. Observe that when you release them, they still fall to the ground.
The watch may run differently due to its internal electrical components operating differently under the influence of a stong magnetic field, but the result will have nothing whatsoever to do with gravity.
You cannot cancel gravity. The only way to experience lower gravitational field strength is to get further away from the center of the earth. Climb a mountain, or build a rocket. That's about it.
- Warren
chroot- u didnt really answer my question, well u techinically did but that wasnt what I was asking. the left middle right object action is taking place, (the magnet, object, magnet) and the pull factor doesn't have to be magnets, but another object. but I was just saying, if you put a watch in the pull field, and it had a net gravity of zero, it would be suspended in air like Lurch said. so by how much time would the watch speed up like that? since he said "slightly faster" sorry for the confusing magnet demo... it doesn't have to be magnets, but anything that has an equal pull factor
Magnets apply a magnetic force, not a (significant) gravitational force. You do not alter the gravity around the watch by suspending it between magnets. Why magnets...why not strings...or for that matter, the fact that it is strapped to your wrist should do...shouldn't it ?
I can't make head or tails out of this question as written, but I can answer a similar question that's interesting.
Suppose one had access to hyperdense materials, far denser than normal matter. (Example: the science fiction story "The Singing Diamond" by Robert Forward, where the hyper-dense material is electron degenerate matter contained in a diamond matrix).
Suppose one then supported a mass of such hyperdense materials on the surface of the earth, such that a point of "zero gravity" was created on the Earth's surface, due to the fact that the attraction to the Earth was exactly balanced by the attraction to the hyper-dense object at said point.
Note that there aren't any magnets in this re-formulation of the question (I don't know what the magnets were doing in the original question), and that there are no magical "gravitational devices" in this re-formulation either.
Suppose one then put a clock at the point where the gravity was canceled out. Make it a very small clock (like a cesium atom) if you like, or extend the region of cancellation by making the hyper-dense object a disk - the details don't matter much, but I will do the calculation for a point mass, it's easier.
Such a clock will run almost exactly at the same rate as a non-suspended clock. The reason for this is that time dilation is proportional to gravitational potential energy, not the gravitational field.
See
Time Dilation Formula
for a reference. This has also been discussed on the Physics Forum in the Relativity Forum a few times.
Now all we need to do is to evaluate the total gravitational potential energy of the suspended clock to figure out the total time dilation. The potential energy a distance R away from a massive object M is
E = -GmM/R = -(GmM/R^2)*R = -g*R
where g is the acceleration of gravity.
With two objects, we have to add together
-g*R + -g*D
where D is the distance that the clock is away from the hyper-dense mass that is cancelling out the Earth's gravity. Because it is cancelling out the Earth's gravity, 'g' is the same acceleration for the Earth and for the hyper-dense object. But because D << R, the total contribution to the gravitatonal potential energy of the hyper-dense mass will be small compared to that of the Earth.
The gravitational time dilation at the Earth's surface is already very small (one part in 7*10^-10) to begin with (see the URL above for the calculation) - and the additional time dilation due to the hyper-dense object will be many times less than that of the Earth (by a factor of D/R).
If you use a magnet or anything else (like your wrist, as Gokul said) to suspend a watch in midair, its rate doesn't change at all from when it is sitting on the ground.
Only gravity causes gravitational time dilation.
well you guys are getting awfully technical on here, and I didnt want to take the time and write out the exact perfect wording, but thanks for the explenation and formula pervect
  • · Replies 31 ·
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 31 ·
