Can we see the interactions between antigens and antibodies in a lab?
  • Thread starter Thread starter Amalan
The discussion revolves around the visibility and interaction of antigens and antibodies in a laboratory setting. Participants explore the challenges of visualizing these molecules and the mechanisms underlying their interactions, including experimental methods to study these relationships.
  • Some participants express curiosity about visualizing antigens under a microscope, noting that many representations are artistic rather than scientific.
  • It is mentioned that antigens are diverse molecules that trigger antibody production, but many are too small to be seen with visible light.
  • A participant questions the "key and lock" model of antigen-antibody interaction, suggesting that antibodies might conform to antigens rather than fitting them precisely.
  • Another participant argues that if antibodies conformed to antigens, binding would be based on morphology rather than chemistry, which would reduce specificity in binding.
  • Experiments using X-ray crystallography are cited as a method to show antigen-antibody complexes, indicating that while direct visualization is challenging, indirect methods exist.
  • A practical laboratory method is proposed where antibodies are immobilized in a column to test binding with antigens, demonstrating that conservation of protein structure across species allows for binding.
Participants express differing views on the visibility of antigens and the nature of their interactions with antibodies. There is no consensus on the mechanisms of binding or the implications of experimental results.
The discussion highlights limitations in visibility due to the size of antigens and the complexity of their interactions with antibodies, as well as the dependence on specific experimental conditions and definitions.
Amalan
Im curious in seeing one under a microscope. google images just has artist interpretations and wikipedia portrays them like lego building blocks. kinda curious to seeing various forms of antigens if anyone knows where to get some good pics?
Biology news on Phys.org
Welcome to PF Amalan, antigens are any molecule/chemical that triggers the production of antibodies in the immune system. As such antigens are hugely diverse, most would be impossible to see under a microscope because they are so small that they are invisible to visible light.
Here's some examples for you
Melittin the principle component of a Bee sting (this is an antigen if you are allergic)
P24 a HIV antigen
Some Rhesus antigens.
Something that you should probably know is that there are many ways of schematically representing molecules known as molecular models
P24 a HIV antigen
if they are impossible to see, how do we know its like a key and lock type deal with antigens and antibodies? How do we not know that the antibody just conforms to the antigens proportions?
Well if the antibody mechanically conformed to the antigen we should see binding on the basis of morphology rather than chemistry, considering all antibodies have pretty much the same physical conformation (but variable chemical regions) it would mean that all antibodies bind to a huge variety of antigens. Conformational changes would make antibody binding far less specific and would still require chemical bonding.
Obviously morphology plays a part but only by providing an appropriate configuration for the correct chemical binding.
Whilst we cannot see with visible light experiments using X-ray crystallography can show antigen-antibody complexes.
Because we can go into a lab and test the idea.
You can build a column with antibodies stuck to the inside and run antigens through it, collecting them at the bottom. The antigens will come out of the column, based on how well they bind on antibodies within the column.
If we look antigens of protein in nature, what we see is that they can bind to antibodies across species boundaries when protein homology is conserved.
For example, if you make rabbit antibodies to say a human protein then use the homologous protein from another species, the antibodies will still bind very well too it, so long as there is conservation of the proteins sequence and structure. If you use a totally unrelated protein, what you find is damn near all of it just passes through the column.
  • · Replies 94 ·
15K
