The band gap discontinuity in DFT?
The discussion revolves around the band gap discontinuity in Density Functional Theory (DFT). Participants explore the reasons behind this discontinuity, the necessity of adding an electron to the Kohn-Sham system for band gap calculations, and the implications of Kohn-Sham orbitals in relation to Slater determinants. The conversation includes technical explanations, historical practices, and references to relevant literature.
  • Some participants suggest that the band gap discontinuity arises from the inadequacies of common functionals in representing exchange interactions.
  • Others explain that to calculate the band gap using DFT, one must compare the energy states of a system with a full valence band to one with an additional electron in the valence band.
  • A participant notes that the practice of adding or subtracting electrons for band gap calculations was common until the early 2000s, after which more sophisticated methods became available due to increased computational resources.
  • There is a discussion about the role of Kohn-Sham orbitals, with some asserting they are not used to form Slater determinants, while others argue that they can be arranged in such a way for hypothetical wavefunctions.
  • Some participants mention that time-dependent DFT can improve the band gap width, particularly for narrow-gap semiconductors.
  • References to specific methods for calculating density of states, including the Tetrahedron method, are provided, although there is uncertainty about their applicability within DFT.
  • Hybrid DFT methods that incorporate Hartree-Fock exchange are mentioned as a way to address band gap discrepancies.
  • One participant expresses confusion about the physical reason for the discontinuity in the Kohn-Sham band gap despite having corrected it using the GW approximation.
Participants express multiple competing views regarding the reasons for the band gap discontinuity and the role of Kohn-Sham orbitals. The discussion remains unresolved, with no consensus reached on several points.
There are limitations in the discussion regarding the assumptions made about the exchange-correlation functional and the applicability of Koopmans theorem to Kohn-Sham orbitals. The conversation also reflects varying levels of understanding about the methods used to calculate density of states.
new_986
Hi everybody...
I've read about the band gap problem of Density functional theory, there is a discontinuity of the band gap when an electron add to the Kohn-Sham system I have two questions could anybody answer me? please
1- why this discontinuity happens anyway?
2- why we need to add an electron to the Kohn-Sham system to calculate the band gap?
with my regards
Nawzad A.
ad 1: As far as I know, the problem is due to not representing well the exchange with common functionals.
ad 2: With DFT you calculate the energy of the ground state. So you have to compare a system where the Valence band is full and the conduction band is empty with one where the valence band contains just one electron.
Dear DrDu...
The Kohn-sham represent the wave function determined by the Slater which known as Slater determinant which is also used in Hartree-Fock method to overcome the symmetry of the electrons am I right?
If this is true, Is this means the Slater determinant does not represent the exchange well? and how please?
To add to the answer of the 2nd Q:
Up to early 2000's it was common to use this approach (add electron, Subtract electron) to compute the band gap using DFT. However, This is not the practice anymore as there are more RAM memory available. The current practice is to calculate high quality electronic density of states using dens K-points grid , fine Fourier Transform grid, and accurate convergence criteria for the electronic iterations. The band gap can be readily obtained then.
new_986 said:
Dear DrDu...
No, the Kohn-Sham Orbitals are never used to form a Slater determinant. They are little more than a computational device to find a good approximation mainly for the kinetic energy.
Interesting. But how do you calculate the density of states? Time dependent DFT?
Still within the framework of DFT , one can obtain the density of states.
Time dependent DFT generally can improve the width of the band gap specially for semiconductors with narrow gap.
I still don't understand how. Do you have a reference?
The following reference explains the so called Tetrahedron method.
"Singular integrals over the Brillouin zone: the analytic-quadratic method for the density ofstates"
M H Boon, M S Methfessel and F. M. Mueller
1986 J. Phys. C: Solid State Phys. 19 5337
"The Eigen states can be expressed in the form of Slater determinant" this is what I saw in the following reference:
" J. Kohanoff and N. Gidopoulos , Density functional theory: basics, new trends and applications (January 31, 2002).
I thing this means the same what I said, If I'm wrong please tell me.
thanks
Nawzad A.
You may arange the KS orbitals in a Slater determinant if you want. But this Slater determinant is only a wavefunction for the hypothetical wavefunction of non-interacting particles which feel the KS potential. It is not a representation of the true wavefunction of the interacting system. Especially it cannot be used to calculate expressions for exchange or correlation (it should be clear that independent particles aren't correlated). However, to calculate the one body expectation values (especially of the kinetic energy), you don't need to form a determinant of the orbitals.
I had a look at the paper, but methinks it does not address how to calculate the density of states in DFT. You may determine some gap in the spectrum of the KS orbitals but there is no reason why this gap should coincide with the gap for e.g. natural orbitals as Koopmans theorem does not hold for KS orbitals.
Hartree Fock method has the exact exchange energy for a single slater determinant. DFT has an approximation for the exchange in the exchange-correlation functional. Most hybrid DFT methods like BL3YP add some exchange from the HF method. Also, band gaps are often not well represented by DFT because of the fictitious Kohn-Sham orbitals. One can still often gain insight from the KS orbitals though. Also a major reason for the disparity is that the exchange correlation functional has a cusp when plotting ionization energy and electron affinity vs. the number of electrons. This cusp is often not built into the functionals.
I think that nowadays the band gap is often calculated solving the Hedin or GW equations. These use often as a starting point the Kohn Sham orbitals. Nevertheless this theory has not much to do with density functional theory per se.
I've done a correction of band gap using GW approximation but I still have no idea about the physical reason of the discontinuity of the KS band gap
How about:
www1.mpi-halle.mpg.de/~sharma/talks/vienna.pdf
DrDu said:
How about:
Thanks Dear
In case you haven't found it already, Perdew, Parr et al published a http://prl.aps.org/abstract/PRL/v49/i23/p1691_1" on the discontinuity in energy with respect to particle number.
16K
