No terminal velocity in a vacuum?
The discussion revolves around the concept of terminal velocity in a vacuum, specifically in the context of dropping a massive weight from a significant height. Participants explore the implications of a vacuum environment on falling objects and the resulting impact velocity.
  • One participant suggests that in a vacuum tube, a dropped weight would not experience terminal velocity due to the absence of drag forces.
  • Another participant calculates the impact velocity using the formula v = √(2gh), asserting that mass does not affect this velocity, resulting in approximately 250 meters per second.
  • Some participants humorously speculate about the catastrophic consequences of such an impact, referring to it as "armageddon."
  • There are claims that in a non-relativistic approximation, the final velocity would be around 800 m/s, with some discussion about the conversion of height from feet to meters.
  • One participant introduces the idea of using a vacuum tube for particle acceleration and proposes a parabolic tunnel for rapid transit between cities.
  • Another participant mentions that terminal velocity is influenced by viscosity forces and questions the conditions under which the √(2gh) approximation holds true.
  • There is a correction regarding the conversion of units, with some participants clarifying their calculations and addressing earlier mistakes.
Participants generally agree that there would be no terminal velocity in a vacuum due to the lack of drag forces. However, there are competing views regarding the specific calculations of impact velocity and the conditions under which certain approximations apply.
Some calculations depend on assumptions about gravitational acceleration being constant, and there are discussions about the validity of the √(2gh) approximation when considering large heights relative to the Earth's radius.
Erazman
if we made a vacuum tube ten thousand feet high, and dropped a million tonne weight into it, it would have no terminal velocity right? how fast would it hit the ground? armageddon? :P
Impact velocity would be approx. [tex]v=\sqrt{2gh}[/tex] and it has nothing to do with mass. When you put numbers in you get that v is around 250 meters per second. The same speed would be if you have dropped the feather. Now, destructive effect depends on mass because kinetic energy which is spent in the moment of "braking" during the impact depends on mass [tex]T=\frac{1}{2}mv^2[/tex]. When you calculate this you get that T is approx 30TJoules which is one-hour energy output of 10 larger power plants.
So basically, yes, armageddon. :smile:
someone should try this out.. just for fun..
lol
Correct, there would not be a terminal velocity - since there's no drag, and the weight doesn't matter. In the non-relativistic approximation, assuming 'g' is roughly constant, the final velocity will be [itex]v = \sqrt {2gh} =~about~800 m/s[/itex]
lets set up a research lab deep underground, with a vacuum tube leading from the surface. We could accelerate particles that would normally be disturbed by other means.. ok now I am talking out of my ass :)
Actually not, a possible means of rapid transit would be to dig a parabolic tunnel between London and New York, Drop a train in in London and if falls out in New York. What an engineering feat that would be!
I think you forgot to convert feet to meters.
Shouldn't the parabolic curve be a little off to work?
terminal velocity appears due a viscosity force like F = -kv ... if this force don't exists, then...
Not sure what you mean by this?
Actually any smooth curve would do the trick.
If "g" is not constant, assuming we start at rest from infinity, the terminal velocity of an object when it hits Earth's surface equals the (minimum) escape velocity from Earth.
The [tex]\sqrt{2gh}[/tex] approximation is only good when h is much less than the radius of the Earth.
I think not. I just wrote "ft" as "m"...my bad.
I get 244 m/s using google calculator. You can see the calculation
here
(this turns out to be 800 ft/sec)
Ummm...yes, my mistake is not that I didn't convert, but I mistyped. :redface:
I got 800 ft/s using my head, g=32 ft/s2 and sqrt(64) = 8 :smile:
  • · Replies 69 ·
18K
  • · Replies 26 ·
12K
  • · Replies 18 ·
  • · Replies 17 ·
