Sphere melting/freezing timescale-scaling (simplest approach)?
  • Thread starter Thread starter bzz77
    Approach Sphere
This discussion focuses on calculating the melting timescales for uniform composition spheres immersed in a hotter liquid, utilizing conduction as the primary heat transfer method. The participant seeks a simplified scaling approach that incorporates latent heat, specifically referencing the Stefan problem. Key assumptions include uniform temperature within the sphere, a constant bath temperature, and temperature-independent material properties. The derived formula for the melting time is τ = (ρrL) / (h(T_b - T_m)), where ρ is density, r is radius, L is latent heat, h is convection coefficient, T_b is bath temperature, and T_m is melting temperature.
  • Understanding of heat transfer principles, particularly conduction and convection.
  • Familiarity with the concept of latent heat in phase changes.
  • Knowledge of the Biot number and its significance in heat transfer analysis.
  • Basic mathematical skills for manipulating equations related to thermal energy and time calculations.
  • Study the derivation and applications of the Biot number in heat transfer problems.
  • Explore numerical methods for solving Stefan problems in melting and freezing scenarios.
  • Investigate the effects of varying convection coefficients on melting timescales.
  • Learn about the role of specific heat capacity and density in thermal energy calculations.
This discussion is beneficial for thermal engineers, physicists, and researchers involved in materials science, particularly those studying phase change phenomena and heat transfer in liquids.
bzz77
Sphere melting/freezing timescale--scaling (simplest approach)?
Hello everyone:
I am new to melting/freezing-type behaviour. I would like to calculate approximate melting timescales for spheres (uniform composition) thrown into a hotter liquid. The spheres would initially be at a lower temperature than their melting point, so they'd have to heat up before melting. I'd like to stick with conduction.
I would like to know if there's a simple scaling-type method (that incorporates latent heat) for getting approximate melting timescales. From my reading so far, it looks these sorts of Stefan problems are usually approached with numerical methods, and I'd like to start with simple scaling-based approximations before diving into the numerical methods!
If anyone could describe how I'd go about doing a reasonable, but simplified timescale calculation for a melting sphere, I'd be very grateful! I don't know where to start.
It's all about the assumptions.
For example, I'll assume that each immersed sphere has a uniform temperature [itex]T(t)[/itex] the entire time. In other words, conduction within the sphere is fast compared to convection between the sphere and the liquid. In other other words, the sphere is not too big, the thermal conductivity of the sphere material is not too small, and the convection coefficient is not too large. Calculate the http://en.wikipedia.org/wiki/Biot_number" to get a handle on whether this assumption makes sense.
I'll assume that the bath is large, so that the bath temperature [itex]T_b[/itex] is constant.
I'll assume that all material properties are temperature-independent.
Convection from the liquid will deliver a thermal power of [itex]hA[T_b-T(t)]=h(4\pi r^2)[T_b-T(t)][/itex] to the sphere, where [itex]h[/itex] is the convection coefficient and [itex]r[/itex] is the radius. The energy that needs to be supplied to melt the sphere is [itex]\rho V[c(T_m-T_0)+L]=\rho(4\pi r^3/3)[c(T_m-T_0)+L][/itex], where [itex]\rho[/itex] is the density, [itex]c[/itex] is the specific heat capacity, [itex]T_0[/itex] and [itex]T_0[/itex] are the initial and melting temperatures, and [itex]L[/itex] is the latent heat of melting.
Now I'll assume that the bath temperature is large compared to the melting temperature [itex]T_m[/itex] and that the melting temperature isn't much larger than the starting sphere temperature [itex]T_0[/itex], so that [itex]T_b-T(t)\approx T_b-T_m[/itex] and [itex]c(T_m-T_0)+L\approx L[/itex].
Then the time required to absorb this energy and melt the sphere entirely is
[tex]\tau=\frac{\rho r L}{h(T_b-T_m)}[/tex]
This is just one example of a scaling analysis in heat transfer. Your assumptions may be different.
  • · Replies 24 ·
  • · Replies 17 ·
24K
