Strange case in finding acceleration
  • Context: Undergrad
  • Thread starter Thread starter tungle
    Acceleration Strange
The discussion revolves around the problem of determining suitable acceleration for a car to reach a destination within a specified time, considering the effects of numerical errors and constraints on acceleration. Participants explore the implications of time intervals on the car's motion and the mathematical relationships involved.
  • One participant describes a scenario where a car must reach a destination at a specific time, using the equation D = V0 t + (1/2)at^2 to find acceleration.
  • Another participant notes that solving the equation for acceleration leads to a final velocity condition (Vf >= 0) to prevent the car from overshooting and reversing back.
  • A question is raised about how to set constraints on acceleration if the calculated value violates the condition for final velocity.
  • Concerns about numerical errors in the calculations are mentioned, with suggestions to reduce errors by adjusting time steps or using more advanced numerical integration methods.
Participants express differing views on how to handle the constraints on acceleration and the implications of numerical errors. There is no consensus on a definitive method to ensure the car arrives at the destination without overshooting.
The discussion highlights potential limitations related to numerical integration methods and the assumptions made in the application of the motion equations. The impact of time discretization on the accuracy of results is also noted.
tungle
"Strange" case in finding acceleration
Hello there, looks like a fantastic forum here. I got a problem popped up during my work, hope you can help me out.
I have a car:
- at a distance D away from destination
- current velocity V0
- time to go t : the time period I want the car to spend until reaching destination
I discretize time into seconds. At every every second, I want to find suitable acceleration (or deceleration) so that it can arrive at destination at t.
I apply this equation
(Given the equation is applied for constant-change in velocity, reapplying it every second yields some error, but it's minor thing)
I came up with something strange:
If t is sufficiently small, then the car arrives exactly at t once. (case 1)
If I set t too high, the car arrives at the destination early (much less than t), go past destination for some time, then go backwards
to reach destination at given t. (case 2)
My question: is there any constraint for t to always yield case 1, preventing case 2 happening.
To be specific, I put an example in the spreadsheet here:
https://spreadsheets.google.com/spr...TGYzRHB1V1RWVjc3ZEE&hl=en_US&authkey=CIyymf8E
Table 2 is where the case 2 happened. Round-up error is ignored.
Thanks much
You can solve this equation for a
The final velocity is
Vf = V0 + at
You want Vf >= 0, otherwise the car will pass the end point and then reverse back to it.
Eliminate a and you get an inequality connecting V0, D and t.
You should be able to see what the inequality means physically, in terms of the average speed of the car during the trip.
(Or if you don't like doing math, just think about what the average speed must be to make the final speed >= 0, and check your conclusion with your spreadsheet).
Hi,
tks for reply AlephZero.
I know Vf >=0 to make the car stop once. But solving equation
for a always yields one value, how can you set constraint on a, say if a got a value that violating the constraint, then what else value should it be?
You are dealing with numerical error. You can reduce the error by reducing the time step, or by using a different numerical integration method. It looks like you are using Euler Integration, http://en.wikipedia.org/wiki/Euler_method, which is simple but gives bad results. There are more advanced iteration schemes which give more accurate results and are more stable. You might want to try http://en.wikipedia.org/wiki/Leapfrog_integration which is almost as simple as Euler, but much better.
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 27 ·
