New Reply
Radioactive Dating Question, Half-Life.
Share Thread Thread Tools
May25-11, 08:46 PM   #1
I apologize for the simplicity of this question in relation to the others on this site.
But I've been curious, and haven't been able to find an answer.
In Radioactive Dating, how do scientists know how much of a certain isotope (ie. Carbon-14, Potassium-40) was there to start with in an object..
For example, if a rock was found to have gone through 3 half lifes of Carbon-14, being 17,190 years old, how would scientists know that the amount of Carbon-14 which was in the rock when it was formed is eight times what it was when they tested it?
Sorry if I'm being confusing and for looking idiotic for posting such a simple question.
Thanks!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> Nanocrystals grow from liquid interface
>> New insights into how materials transfer heat could lead to improved electronics
May25-11, 09:56 PM   #2
Recognitions:
Quote by Wreak_Peace View Post
Thanks!
Carbon dating is used for organic material, and the trick is that you assume that a living organism is constantly replenishing its supply of C-14, so the ratio of C-14 to the other carbon in the organism is equal to the naturally occurring ratio (about 1 atom in 1 trillion is C-14). However, once the organism dies, the C-14 is no longer replenished, and the ratio of C-14 to non-radioactive carbon begins to decrease as the C-14 decays. So, by measuring the ratio of C-14 to other carbon, you can tell how long ago something died. However C-14 dating can't go back very far, because the half-life of C-14 is only around 5700 years. I think the limit of C-14 dating is around 10 half-lives or so, so it can't be used to reliably date samples older than about 57000 years.
Samples of rock are typically dated using other radioisotope ratios (e.g. Ar-39/Ar-40 dating), but as far as I know, each one of those requires a similar assumption about when the "clock" for the decay started. With argon dating, it has to do with cooling of molten rock ... the red-hot liquid magma will exchange argon with the atmosphere, so while the rock is liquid, the ratio stays constant at the natural abundance. However, when the rock cools, it passes through something called the closure temperature. Below this temperature the exchange process stops, and that is the point where you start counting.
May26-11, 04:42 PM   #3
Ohh. So there are ratios. Thanks! that clears things up!
New Reply
Tags
carbon, dating, half, life, radioactive
Thread Tools
Similar Threads for: Radioactive Dating Question, Half-Life.
Thread Forum Replies
Half-life of radioactive substance Calculus & Beyond Homework 1
Half Life of radioactive element High Energy, Nuclear, Particle Physics 6
Half Life of radioactive element Introductory Physics Homework 1
Half Life of Radioactive Isotopes High Energy, Nuclear, Particle Physics 1
half Life of radioactive insulin Chemistry 1
