Record Sounds Beyond Human Hearing: Can Recording Devices Alter Frequencies?
  • Thread starter Thread starter shadow of a d
    Sound
The discussion centers around the capability of consumer-grade recording devices to capture sounds outside the human hearing range and whether these sounds can be made audible upon playback. Participants explore the implications for recording technology, particularly in relation to claims about electronic voice phenomena (EVP) and the nature of sound reproduction.
  • Some participants propose that it is possible for recording devices to capture sounds outside the human hearing range, but they emphasize the need for software to alter these sounds for playback.
  • Others argue that analog devices can also be designed to shift frequencies without the need for digital technology, citing examples like bat detectors that convert ultrasound into audible sound.
  • One participant expresses skepticism about the claims surrounding EVP, suggesting that they stem from the brain's tendency to interpret random sounds rather than any paranormal phenomena.
  • Concerns are raised about the quality of recording devices, with a participant stating that poor-quality equipment could distort sounds, thereby invalidating any results collected.
  • Another participant shares a list of patents related to high-frequency sounds and devices, indicating ongoing interest and research in this area.
Participants exhibit a mix of agreement and disagreement. While some acknowledge the possibility of recording sounds outside human hearing, there is contention regarding the necessity of digital software for playback and the validity of claims related to EVP. The discussion remains unresolved with multiple competing views presented.
Participants note the limitations of recording devices and the potential for distortion, as well as the dependence on definitions of sound and technology used. There is also an acknowledgment of the need for high-quality equipment to ensure accurate sound reproduction.
shadow of a d
Is it possible for consumer grade recording devices to record sounds outside of the human hearing range, but be audible upon playback? In other words, is it possible for recording devices to alter frequencies in any way?
Computer science news on Phys.org
Welcome to PF! In response to your question yes of course it's possible, shifting the frequency is simple. Why do you ask?
I mean without the aid of software. I'm trying to write an article in response to claims of "EVP" being infrasound or ultrasound. I realize that is you change the speed of the playback, it would allow you to hear the sounds, but i wondered if the device itself (analog or digital) altered it in any way.
Do you mean on their own?
You could certainly record something outside of our hearing range, but you would then need to use computer software (with a digital recorder) to alter it so you could hear it.
I'm curious why you came to scepticism and debunking for such a question (although I've got a good feeling why)?
EDIT: Answer noted.
EVP is the brain trying to make sense of random sounds. There's really no more to it (I'll add the disclaimer "as far as we're aware").
All the talk of 'infrasound' and 'ultrasound' is just people trying to use flashy words to describe the above and make it sound paranormal.
I agree, and have mentioned that, but I'm attempting to tackle the other angles that proponents have put forth.
There's really no other angles, just attempts to circumvent explanations in ever more grasping ways.
OK, so let's go one step further and look at the cause. What they are claiming is that something emits ultrasound and that the recorder picks it up - ok, I'll buy that for now - and then during playback without alteration, they are able to hear it - this is where my acceptance drops off.
Perhaps a poor quality device may be subject to slight distortion during recording/playback, but that's something you want to avoid when recording these things. The last thing you want is poor equipment giving false results - invalidating anything you collect.
The key point for you, would be the above. That equipment that doesn't reproduce the source sound, as close to the original as possible (without distortion), is useless and invalidates results. If it picks up ultrasound, it must reproduce it as ultrasound. If it doesn't, it is skewing your results and invalidating them. You can certainly alter it on a computer to try and work with it, but a device doing it 'accidentally' is not acceptable for data collection.
Awesome, thank you.
You don't need computer software and digital technology to do this. Radios using only analog electroncs are easy enough to design, and it doesn't matter where the input signal comes from. It could be any sort of transducer that converts something into a high frequecny electrical signal, instead of a radio transmitter.
"Bat detectors" work by pitch shifting ultrasound into the human audio range using the same principles.
I never said you did and I even included a caveat to show I was referring only to digital recorders.
I did so as most modern tech uses digital only so it seemed most applicable to me.
to the op,
this is information on ultra high frequency sounds and patents around them.
here is a patent for a silent sound spread spectrum.
http://www.google.com/patents?hl=en&lr=&vid=USPAT5159703&id=sU4hAAAAEBAJ&oi=fnd&dq=Silent+Subliminal+Presentation+System&printsec=abstract#v=onepage&q&f=false
also
  • Flanagan GP. Patent #3393279 “Nervous System Excitation Device” USPTO granted 7/16/68.
  • Puharich HK and Lawrence JL. Patent #3629521 “Hearing systems” USPTO granted 12/21/71.
  • Malech RG. Patent #3951134 “Apparatus and method for remotely monitoring and altering brain waves” USPTO granted 4/20/76.
  • Stocklin PL. Patent #4858612 “Hearing device” USPTO granted 8/22/89.
  • Brunkan WB. Patent #4877027 “Hearing system” USPTO granted 10/31/89.
  • Thijs VMJ. Application #WO1992NL0000216 “Hearing Aid Based on Microwaves” World Intellectual Property Organization Filed 1992-11-26, Published 1993-06-10.
  • Mardirossian A. Patent #6011991 “Communication system and method including brain wave analysis and/or use of brain activity” USPTO granted 1/4/00.
  • O'Loughlin, James P. and Loree, Diana L. Patent #6470214 "Method and device for implementing the radio frequency hearing effect" USPTO granted 22-OCT-2002.
hopefully this will get you pointed in a good direction on ultra high frequency sounds.
  • · Replies 23 ·
  • · Replies 31 ·
  • · Replies 27 ·
