How Do You Calculate the Volume of a Solid Rotated Around y = -3?
  • Thread starter Thread starter olicoh
    Solids Volume
The problem involves calculating the volume of a solid generated by rotating a region bounded by specific lines around the axis y = -3. The context is centered on understanding the setup and evaluation of the integral for volume calculation.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the setup of the integral and the evaluation process, questioning the signs of the results obtained. There is a focus on ensuring the integral is correctly evaluated to yield a positive volume.
Some participants have provided guidance on re-evaluating the integral, noting that the original poster encountered negative results. Multiple interpretations of the integral's evaluation are being explored, with some participants arriving at a consistent positive result.
There is mention of discrepancies in results when using different calculators, indicating potential confusion or errors in the evaluation process. The original poster expresses concern over obtaining negative values for volume, which is not feasible.
olicoh
In Problems 11-15, let R be the region bounded by the lines y = −2x – 4, y = 6, and x = −2. Each problem will describe a solid generated by rotating R about an axis. Find the volume of that solid.
14) The solid is generated by rotating R about y = −3.
R(x)=6-(-3)
r(x)=(-2x-4)-(-3)
A(x)=pi[(9)2-(-2x-1)2] = pi[81-(4x2+4x+1]
V=(pi) int[-5,-2](-4x2-4x+80)
=pi(-4/3x3-2x2+80x)[-5,-2]
Ok this is where I realize something is wrong because when I plug -5 and -2 into the equation, the number is negative, which is impossible since volume cannot be negative. I keep getting -774pi. Ah! :mad:
i got [tex] \frac{394\pi}{3}[/tex]
Your integral looks setup correctly re evaluted your integral.
? How did you get that? I keep getting a negative number because of that 80x.
i just evaluated the integral from -5 to -2
F(-2) - F(-5)
actually i got a different number the second time i made a little mistake, but you should get a positive number
Huh... That's odd. I was plugging it into my graphing calculator and it kept spitting out a negative number. I just plugged it into a calculator online and it got 126. Weird. So I'm assuming the answer is 126pi.
Thanks!
ya i got 126pi the second time too.
no problem
  • · Replies 20 ·
  • · Replies 34 ·
