What'd I do wrong? [Angular Kinematics]
The discussion focuses on solving angular kinematics problems involving constant angular acceleration. The first problem involves calculating angular acceleration and final speed of a centrifuge, where the correct angular acceleration is determined to be 0.07 rad/s², contrary to the user's calculation of 0.035 rad/s². The second problem pertains to a car's deceleration, requiring the use of rotational kinematic equations and the relationship between linear and angular displacement. Key equations include θ = θ₀ + ω₀t + ½αt² and ω = ω₀ + αt.
  • Understanding of angular kinematics and rotational motion.
  • Familiarity with the equations of motion for constant angular acceleration.
  • Basic knowledge of unit conversions, particularly between revolutions per minute (rpm) and radians per second (rad/s).
  • Ability to relate linear and angular quantities, such as displacement and velocity.
  • Study the derivation and application of rotational kinematic equations.
  • Learn about the conversion between different units of angular velocity, specifically rpm to rad/s.
  • Explore the relationship between linear and angular motion, focusing on the formulas s = rθ and v = rω.
  • Practice solving problems involving angular acceleration and deceleration in various contexts.
Students and educators in physics, particularly those focusing on mechanics, as well as engineers and professionals working with rotational systems and dynamics.
AERam
The problem is:
"Pilots can be tested for the stresses of flying high-speed jets in a whirling "human centrifuge" which takes 1.0 min to turn through 20 complete revolutions before reaching its final speed. (a) What was its angular acceleration (assume constant), and (b) what was its final speed in rpm?"
I converted 20 rpm to rps by dividing 20 by 60, and got .333 Hz. Then I plug that into:
omega=2pi f
omega=2pi (.333)
omega=2.09 rad/s
I plug that into alpha = delta omega / delta t, so that's (2.09/60), and I get roughly .035. But the book says the answer is .07! What did I do wrong?
There's also another problem I'm stumped with; I would appreciate a hint of some sort, because I don't know what to do with some of the numbers.
"The tires of a car make 65 revolutions as the car reduces its speed uniformly from 100km/h to 50 km/h. The tires have a diameter of .8m. (a) What was the angular acceleration? (b) If the car continues to decelerate at this rate, how much more time until it stops?"
Any help is appreciated!
You found the average speed. Under constant acceleration, omegaaverage = 1/2(omega final) assuming you started from rest. For the second problem you should at least start by finding the circumference of the tire and converting k/h to m/s.
AERam,
the simplest way to do your first problem is to write down the rotational kinematic equations for constant angular acceleration:
[tex]\theta=\theta_0+\omega_0 t +\frac{1}{2}\alpha t^2[/tex]
[tex]\omega=\omega_0+\alpha t[/tex]. (Hopefully, these look familiar.)
You can set your starting point [itex]\theta_0=0[/itex].
If you start from rest, [itex]\omega_0=0[/itex].
Yes, you could use the average-angular-acceleration formula
[tex]\alpha_\text{avg}=\frac{\Delta \omega}{\Delta t}= \frac{\omega_f-\omega_0}{t_f-t_0}[/tex]. However, you must use the final angular-velocity [itex]\omega_f[/itex]---not the average-angular-velocity [itex]\omega_\text{avg}=\frac{\Delta \theta}{\Delta t}[/itex] (as vsage pointed out).
For your second problem,
recall the relationship between linear displacement [itex]s[/itex] and angular displacement [itex]\theta[/itex] (with a constant radius [itex]r[/itex]):
[tex]s=r\theta[/tex].
  • · Replies 32 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 16 ·
