How to calculate the moment of inertia of the rigid body?
by copperboy
Tags: body, inertia, moment, rigid
copperboy
copperboy is offline
#1
Oct28-04, 11:47 PM
P: 8
I don't know how to calculate the following rigid bodies with different geometries, can anybody help me?
Thin spherical shell: I=(2/3)MR^2
Solid sphere: I=(2/5)MR^2
Thanks in advance.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
Tide
Tide is offline
#2
Oct29-04, 01:03 AM
Sci Advisor
HW Helper
P: 3,149
Use the definition of moment of inertia:
[tex]I = \int r^2 dm[/tex]
In the case of the shell the element of mass is [itex]dm = M {dA} /{4 \pi R^2}[/itex] where [itex]dA = R^2 \sin \theta d\theta d\phi[/tex]. The distance to a point on the shell from the z-axis is [itex]R^2 \sin^2 \theta[/itex] so
[tex]I = \frac {M}{4 \pi R^2} \int_{0}^{2 \pi} d\phi \int_{-\pi /2}^{\pi /2}R^4 \sin^3 \theta d\theta[/tex]
from which the desired result follows.
In the case of the solid sphere you will work with a volume integral.
copperboy
#3
Oct30-04, 09:08 AM
P: 8
Could you please explaim why [itex]dA = R^2 \sin \theta d\theta d\phi[/tex] in detail?
arildno
arildno is offline
#4
Oct30-04, 01:04 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by copperboy
Consider an area segment dA on a sphere with radius R.
We approximate this with a rectangle:
a)Two of the sides are arclengths along great circles; the length of each of these is [tex]Rd\theta[/tex]
b) The other two are arclengths in THE HORIZONTAL PLANE; the local radius there is [tex]R\sin\theta[/tex]
Hence, the arclenth is [tex]R\sin\theta{d\phi}[/tex]
c) Multiplying together, we get:
[tex]dA=R^{2}\sin\theta{d\theta}d\phi[/tex]
Tide
Tide is offline
#5
Oct30-04, 01:06 PM
Sci Advisor
HW Helper
P: 3,149
dA is a differential element of area on a spherical surface using spherical coordinates and it represents, to lowest order in differentials, the area of a rectangle [itex]R \sin \theta d\phi[/itex] high and [itex]R d\theta[/itex] units wide.
ruffneck2
#6
Nov2-04, 03:26 AM
P: n/a
This is the first time i'm involved in physics studies.I'm having a lots of problems using these formulas and the text book i'm using does not make it easy. one from "James S. Walker"
Can someone please explain how and when to use these formulas.
Thank You.
siddharth
siddharth is offline
#7
Nov2-04, 04:15 AM
HW Helper
PF Gold
siddharth's Avatar
P: 1,198
This is one way to look at it
You must be familiar with the equation F=ma.
We use the Moment of Inertia to find the Torque.
Like how the force is directly propotional to acceleration, Torque is directly propotional to angular acceleration, the propotionality constant being the moment of inertia.
Also remember about what axis you are taking the moment of Inertia while solving problems. In most problems i have encounterd which ask you to find the angular acceleration, first find the torqure taking the vector product R X F. Next find the moment of inertia of the object about the required axis. Then the acceleration can be found
Also, for a solid sphere, perphaps deriving the moment of inertia by intergrating thin rings would be easier than a volume intergral?
Register to reply
Related Discussions
Moment of Inertia Tensor for a Flat Rigid Body Advanced Physics Homework 0
Rigid body moment of inertia Introductory Physics Homework 4
Newtonian mechanics - extended rigid body's rotation, moment of inertia Introductory Physics Homework 1
Moment of Inertia of Human body Advanced Physics Homework 4
