Mass of a particle in magnetic field
The problem involves a positively charged particle moving in a magnetic field, where the participant seeks to determine the mass of the particle based on its velocity, charge, and the magnetic field strength. The context is rooted in concepts of magnetic forces and circular motion.
  • Participants discuss the relationship between magnetic force and centripetal force, with one questioning the relevance of centripetal force given the particle's motion. Another participant attempts to apply a formula relating radius, mass, velocity, charge, and magnetic field strength.
The discussion includes attempts to clarify concepts and apply relevant equations. Some participants provide guidance on the relationship between the forces involved, while others explore the implications of the formula used for calculating mass. There is no explicit consensus on the correctness of the calculations presented.
Participants express frustration with the lack of example solutions in their course material, which may influence their understanding and approach to the problem.
sonic52260
A positively charged particle (q= 1.6 x 10^-19C) is traveling at 1.9 x 10^4 m/s perpendicular to a 1.0 x 10^-3 T magnetic field. If the radius of the resulting path is 0.40m, what is the particles mass?
F=Qvb
B= u x N/L x I
This chapter has failed to give me an example solution to any questions so far, it's a terribly done online course,
Anyways, I really appreciate any help in solving this, it'll make the rest of the chapter much, much more understandable.
Have you studied uniform circular motion? Have you heard of centripetal force? Sometimes you may have to use what you know from outside the one chapter from which you trying to solve problems.
Since magnetic force is perpendicular to the magnetic field, wouldn't centripetal force be not be an issue as the particle is moving perpendicular?
Oh, nevermind about the last post there.
How about:
R= (mv)/(qB)
and the particle would be traveling around the field, not in a straight line. My bad on that one.
So getting mass from that formula using
.4m= (mx1.9E4)/(1.6E-19 x 1E-3)
The mass would end up being
3.4E-27kg
Let me know if i got this sucker right :)
9K
  • · Replies 16 ·
  • · Replies 31 ·
