WHy OXygen can react with metal?
  • Thread starter Thread starter no idea
    Metal Oxygen
Oxygen (O2) reacts with metals due to differences in electronegativity, particularly between iron and oxygen, leading to the formation of ionic bonds. The covalent bonds in molecular oxygen break when interacting with iron, resulting in iron oxidation to Fe(OH)3. Additionally, the reaction occurs in the presence of moisture, where a thin aqueous film facilitates the dissolution of iron. In contrast, copper exhibits passive film formation, which inhibits similar reactions.
  • Understanding of covalent and ionic bonding
  • Knowledge of electronegativity concepts
  • Familiarity with oxidation states, particularly Fe(3+)
  • Basic chemistry of metal reactions with oxygen
  • Research the process of metal oxidation in aqueous environments
  • Study the properties and behavior of passive films in metals
  • Explore the role of humidity in metal corrosion
  • Learn about the differences in reactivity between various metals and oxygen
Chemistry students, materials scientists, and professionals involved in corrosion prevention and metal treatment processes.
no idea
WHy OXygen can react with metal?As i know , oxygen(O2) is bonded by covalent bond and it should be neutral charge. So how can the metal react with oxygen?
Chemistry news on Phys.org
The difference of electronegativity between iron and oxygen is greater than the one between two oxygens. That means the attraction between iron and oxygen is higher. As a result, the covalent bond between the oxygen ions break and create an ionic bond with iron.
Hello Miracles, you are right. However, there is one more thing; metal and molecular oxygen react in solution, that is, a very thin aqueous film formed by humidity on iron dissolves some of iron with the aid of molecular oxygen dissolved in that film. Iron has a greater stability in 3+ state, so eventually a significant amount of iron is oxidized to Fe(OH)3.
The same thing does not operate well in copper; we call the effect as "passive film formation".
  • · Replies 34 ·
