Varying Fine Structure Constant?
The discussion revolves around the fine structure constant, particularly its value at different energy levels and the implications of its potential variation over time. Participants explore theoretical and experimental perspectives on whether the fine structure constant changes with energy and what fundamental constants might influence it.
  • Some participants note that the fine structure constant is typically regarded as 1/137 at normal lab energies but appears to approach 1/128 at high energies, raising questions about the reasons for this variation.
  • There is a mention of evidence suggesting that the fine structure constant may have been lower in the past, specifically referencing astrophysical observations by J.K. Webb et al., though this claim has faced challenges from more recent measurements.
  • One participant argues that the fine structure constant does change due to factors such as renormalization group flow and thermodynamic contamination, suggesting that coupling constants scale with energy and temperature.
  • Another participant references BSBM theory, which posits that while certain constants remain fixed, the charge (e) may vary, indicating a theoretical framework for understanding changes in the fine structure constant.
  • There are references to various papers and studies that either support or contest the notion of a varying fine structure constant, including a recent publication that provides a stringent upper limit on its possible variation.
  • Participants express differing views on the implications of observed values of the fine structure constant and the significance of its apparent stability across vast timescales and distances.
Participants do not reach a consensus on whether the fine structure constant varies with energy or time. Multiple competing views are presented, with some arguing for its variability and others asserting that experimental data suggests it remains constant.
Limitations include unresolved mathematical steps regarding the variation of the fine structure constant and dependence on specific theoretical frameworks. The discussion also highlights the complexity of defining constants in the context of high-energy physics.
sor2char
This question may have been asked a thousand times on here so please diredt me to the relevant post if that is the case.
During a particle physics lecture I was told that although the fine structure constant is widely regarded as being 1/137 at normal lab energies, it seems to tend towards 1/128 at high energies.
The lecturer refused to tell us why this occurred and even told us to ask other lecturers to watch them get uncomfortable.
Anyway the best I got was look in Nature.
Found out that there is evidence that it used to be lower in the past, but wondered if anybody could elaborate on which of the fundamental constants used to determine the fine structure constant varied at high energies.
What is the question? Why does it vary with energy, or why does it seem to tend towards 1/128 (which is not exactly true, by the way)?
There is only one "apparent" observation that the fine structure constant (alpha) might have been different in the past, and that was based on astrophysical observation by J.K. Webb et al. However, since then, there have been a number of measurements of alpha, that have contradicted that. For an overview, please read Oct. 2004 issue of Physics Today, Page 40. In fact, just this week, a more stringent upper limit on the possible variation of alpha was published in PRL [E. Peik et al, PRL v.93, p.170801 (2004)] that throws doubt into what Webb et al. measured.
So if we are to go by on the experimental data alone to-date, there are more overwhelming evidence that alpha hasn't been changing.
Zz.
Sorry, but what does et al mean? Please tell me it's not part of his name.
-Spencer
You have for example BSBM theory, a theory of varying alpha. In this theory, c and hbar are constants, while e varies. More info here
http://arxiv.org/abs/astro-ph/0306047
No, the fine structure constant does change, even in vanilla field theory (this drives me absolutely nuts, crackpots always like to assign a value to something that was never intended to have a 'constant' value) .
There can be several well understood reasons for this.
1) The renormalization group flow
In QED coupling constants will run based on regularization schemes. Physically you can picture this as having a bunch of positron-electron pairs popping into existence around the vacuum, and creating a dielectric effect around the electron (shielding it from photon interactions).. The effective coupling constant will thus increase as energy goes up. The point.. Coupling constants scale with energy.
2) Thermodynamic contamination
For closely related reasons, sometimes (I should say always) vacuum values are contaminated by experiments outside absolute zero. Theoretically this is usually absorbed into the interaction constants (to first order). Thus, again, 'constants' will scale with temperature as well.
You should blame it all on Feynman then. He was perfectly aware of the vacuum polarization and charge renormalization issues you're mentioning here. After all, that was part of the work for which he earned the Nobel price. Still he urged physicist to investigate. In fact he mentioned both the shielded and unshielded coupling value when he did so, including the reason why they are different...
The fact that a value seems to settle down with a precision of at least 10,11 digits throughout the universe and throughout time is not necessarily meaningless.
Regards, Hans
(edit) PS. The long distance value of the fine structure constant stays the same up to the GUT unification level. Where it changes is at the short distances corresponding to the energy.
(Just imagine what it would mean, if the the proton's field was slighty stronger than the electron's field, for objects like the Earth or the sun).
Structure Lecture...
While on QED topic, what is the equation that defines the unshielded classical Electroweak fine structure constant?
I am looking for an equation that describes the classical case:
[tex]\propto_s = \frac{f^2}{\hbar c}[/tex] - strong
[tex]\propto_e = \frac{K_e q^2}{\hbar c}[/tex] - electromagnetism
[tex]\propto_{ew} = \frac{g^2}{\hbar c}[/tex] - electroweak ?
[tex]\propto_w = \propto_s \sqrt{ \frac{T_\Delta}{T_\Sigma}}[/tex] - weak
[tex]\propto_g = \frac{G m_p^2}{\hbar c}[/tex] - gravity
What is the actual value for the unshielded classical Electroweak fine structure constant?
Is the actual value for the unshielded classical Electroweak fine structure constant equal to the Fermi coupling constant [tex]G_F[/tex]?
[tex]\propto_{ew} = G_F[/tex] ?
Reference:
http://hyperphysics.phy-astr.gsu.edu/hbase/particles/weastr.html#c1
[/color]
This is one of my personal favorites on this subject
http://arxiv.org/abs/nucl-th/0309048
Many others also exist pointing to the conclusion the fine structure constant has not measurably changed for billions of years, if ever.
-Spencer
et alanes (Latin)
and others (<- not 100% sure about the translation)
Should be et al = et alia. Alia is the plural of alium, meaning another thing. You can also have et alii with the plural of alius, another person. Strictly speaking you should pay attention to what kind of list you're summarizing: things or people? But nobody in these degenerate latter days gives a hoot about that.
meteor said:
according to this paper, there has been observed evidence for a variation of alpha in quasar absortion spectra...
http://arxiv.org/abs/physics/0407141
Consider that the paper that I cited earlier [E. Peik et al, PRL v.93, p.170801 (2004)] is more recent, is published in PRL, has a higher certainty than measurement from a quasar absorption, is doing exactly what they suggest should be done ("A laboratory measurement of how these transition frequencies vary over time is vital in determining whether alpha is varying today"), and contradicts their findings, which one would you put more credibility on?
Zz.
  • · Replies 16 ·
  • · Replies 163 ·
29K
  • · Replies 124 ·
24K
