Thermal physics; specific heat capacity
The discussion centers on calculating the thermal energy transfer between a heated copper lump and water using specific heat capacities. The specific heat capacity of water is 4200 J/kg·K, while that of copper is 390 J/kg·K. The water's temperature rises from 15°C to 35°C, resulting in a thermal energy gain of 3.78 x 104 J. The initial temperature of the copper is determined to be 843°C, as both substances reach thermal equilibrium at 35°C.
  • Understanding of specific heat capacity
  • Familiarity with the equation Q=mcΔT
  • Basic knowledge of thermal energy transfer
  • Concept of thermal equilibrium
  • Study the concept of thermal equilibrium in detail
  • Explore experiments involving specific heat capacities of different materials
  • Learn about calorimetry and its applications in thermal physics
  • Investigate the principles of heat transfer in various states of matter
Students studying thermal physics, educators teaching calorimetry, and anyone interested in understanding heat transfer principles in experiments.
saccapella
In an experiment to measure the temperature of the flame of a Bunsen burner, a lump of copper of mass 0.12 kg is heated in the flame for several minutes. The copper is then transferred quickly to a beaker, of negligible heat capacity, containing 0.45 kg of water, and the temperature rise of the water measured.
a)Temperature of water rises from 15 to 35degrees. Calculate thermal energy gained by the water.
b)Calculate the temperature reached by the copper in the flame. Assume no heat is lost when copper is transferred.
Specific heat capacity of water = 4200jkg^-1K^-1
Specific heat capacity of copper = 390jkg^-1K^-1
Q=mc(final temperature - initial temperature)
a)Q=0.45*4200*20
Q=3.78*10^4J
b)none... this is where i got stuck :/ help please!
The heat that ended up raising the water's temperature came from somewhere. Where did it come from?
The copper?
saccapella said:
The copper?
Yes, the copper. How much heat did it give up to the water? What is the copper's final temperature?
3.78*10^4J...
3.78*10^4J=0.12*390*change in temperature
so change in temperature = 808?
This is where I get stuck on...I don't know how to find the final temperature
What is the final temperature of the copper as it sits in the water bath?
35 degrees
Edit: Misread what you said lol, final temperature of the copper as it sits in the water bath? 843?
Right. The copper and water reach temperature equilibrium. So Tf = 35, and you're looking for Ti for the copper. If Q is your heat value, mc the copper mass and cc the copper specific heat capacity, then
Q = mc*cc*ΔT
where ΔT is the difference between the initial and final temperatures (I've assumed all positive values for simplicity).
saccapella said:
35 degrees
No, no, you were correct the first time (before edit). The water and copper reach an equilibrium temperature of 35 degrees. 843 degrees, then, is the initial temperature of the copper when it is first placed into the water.
Ohh, I see what you did. Thanks!
gold penny lab, i remmber doing this it was fun. sorry we didint have these questions, maybe you should search for gold penny lab.
