Proving Compactness of a Topological Group Using Subgroups and Quotient Spaces
The discussion revolves around the proof of compactness of a topological group G given that a subgroup H and the quotient space G/H are compact. Participants explore various aspects of the proof, including the properties of closed mappings, the implications of compactness, and the conditions under which the argument holds.
  • One participant presents a proof that if H is compact and G/H is compact, then G should also be compact, relying on the closed mapping property of the natural mapping from G to G/H.
  • Another participant questions the validity of the proof by suggesting that if G is isomorphic to H x G/H, the argument may not hold.
  • Some participants discuss the necessity of the Hausdorff property for the closed mapping, with one later retracting that concern.
  • A definition of a proper map is introduced, along with a theorem stating that if a proper map's codomain is compact, then the domain is also compact.
  • Participants explore the implications of the finite intersection property (fip) and how it relates to the compactness of the intersections of closed sets.
  • There is a suggestion that the argument may work locally, hinting at the possibility of a locally trivial fibration.
  • One participant expresses doubt about the success of the proposed argument, while another reassures them that no errors were found in their reasoning.
Participants express differing views on the necessity of certain properties (like Hausdorff) and the implications of the quotient structure. The discussion remains unresolved regarding the validity of the proof and the conditions under which it holds.
Some participants note that the proof may depend on whether H is a normal subgroup and the implications of the quotient space not being a group. There are also discussions about the assumptions required for the closed mapping property to hold.
Lie
Hello!
Could anyone help me to resolve the impasse below?
Th: Let G be a topological group and H subgroup of G. If H and G/H (quotient space of G by H) are compact, then G itself is compact.
Proof: Since H is compact, the the natural mapping g of G onto G/H is a closed mapping. Therefore if a family S of closed subsets of G has the finite intersection property, then so does {g(F): F in S}. So that G/H is compact, then [tex]\bigcap_{F \in S} g(F) \neq \varnothing .[/tex] But as I conclude that [tex]\bigcap_{F \in S} F \neq \varnothing \; ?[/tex]
If necessary we also know that G/H is Haudorff space.
Thankful! :)
what if the quotient splits the group? I.e. what if G is siomorphic to H x G/H?
Then in general, just off the top of my head, maybe this is true locally, i.e. maybe the map G-->G/H is a locally trivial fibration
No!
I don't understand!
assume it splits. then could you do it?
Can I do that G/H is not a group? Remember that H is only one subgroup. It is not normal!
Hello Lie! :smile:
I wonder how you know this, don't you need some kind of of Hausdorff property for this?
EDIT: never mind about this, you don't need Hausdorff.
Anyway, the following could help you:
Definition: We call f a proper map if it is continuous, closed, surjective and if every [itex]f^{-1}(y)[/itex] is compact (=we say that the fibers are compact).
Theorem: If [itex]f:X\rightarrow Y[/itex] is proper and if Y is compact, then X is compact.
Proof: Note that closedness of f is equivalent with:
For all open U containing [itex]f^{-1}(y)[/itex], there exists an open neighbourhood W of y, such that [itex]f^{-1}(W)\subseteq U[/itex].
This equivalence is easy to see by taking [itex]W=Y\setminus f(X\setminus U)[/itex].
So, now take an open cover of X. For each y in Y, we know that [itex]f^{-1}(y)[/itex] is non-empty and compact and thus covered by a finite number of our covers. Let [itex]U_{y,1},...,U_{y_n}[/itex] be the elements of our cover. Then by the above, there exist [itex]W_{y,i}[/itex] such that
[tex]f^{-1}(W_{y,i})\subseteq U_{y,i}[/tex]
This forms an open cover of Y and thus we can take an finite subcover. This finite subcover is the one we're looking for...
micromass said:
Hello Lie! :smile:
OK! I don't really need Hausdorff.
The natural mapping g of G onto G/H is a closed mapping, continuous, surjective and every [itex]g^{-1}(xH)[/itex] is closed. Why it's proper?
micromass said:
Theorem: If [itex]f\colon X \to Y[/itex] is proper and if Y is compact, then X is compact.
This result is interesting, but I would try to use my argument above.
Thankful! :)
We have [itex]g^{-1}([x])=xH[/itex]. Now H is compact, and thus every translation xH of H is compact as well.
Very well, but I doubt it's going to work.:frown:
Indeed! :)
Tip of Hewitt & Ross! ;)
What about this: Take [itex](F)_{F\in S}[/itex] with the fip. I now form all finite unions of this collection and I get a collection [itex](F^\prime)_{F^\prime\in S^\prime}[/itex]. Clearly this has the fip and the intersection of this collection is nonempty if and only if the original collection is nonempty.
By compactness we know that
[tex]\bigcap_{F^\prime\in S^\prime}{g(F^\prime)}[/tex]
is nonempty, thus take an [x] in it. By compactness of xH it follows that of [itex]\bigcap_{F^\prime\in S^\prime}{F^\prime}=\emptyset[/itex], then there exist a finite number whose intersection is empty. But because we have chosen the [itex]F^\prime[/itex] to be closed under unions, it follows that [itex]Hx\cap F^\prime=\emptyset[/itex] for some [itex]F^\prime[/itex], but then g(Hx)=[x] is not an element of
contradiction...
Hope I didn't make any silly mistakes here...
contradiction...
Excuse me! I was very busy lately and I could not move from here. Not found any error! Thank very much. :)
  • · Replies 32 ·
  • · Replies 0 ·
  • · Replies 100 ·
13K
  • · Replies 69 ·
9K
